Tranny Frame Housing Removal - Ford Powerstroke Diesel Forum
post #1 of 22 Old 04-09-2013, 08:25 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
This has turned into a challenge.
Impact wrench running 90 PSI can't break it loose.
Cheater bar Nope.
Soaked it with PB blaster, will add another shot tomorrow am and then try again tomorrow after work.
I'm pretty sure this hasn't been removed since new 120K ago.
Started to chew the shoulders off the housing nut.
Any Ideas?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 22 Old 04-09-2013, 08:28 PM
rdunagan's Avatar
not sure what the tranny frame housing is
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #3 of 22 Old 04-09-2013, 09:18 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
3/4" impact.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #4 of 22 Old 04-09-2013, 09:40 PM
Turbos = Witchcraft
TooMuch03's Avatar
Do you mean the cross member at the read of the tranny? Or the bellhousing? Breaker bar and three feet of pipe worked for me on the cross member. If it is the bellhousing, you sir have a bigger rust problem than us in the upper Midwest... I didn't think that was possible.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #5 of 22 Old 04-09-2013, 10:02 PM
PGreenSVT's Avatar
Heat is your friend on this Denny. If you don't have an oxy/acetylene available pick yourself up a MAP gas torch at your favorite hardware store and heat the crap out of it. Had to use mine last week to get the rotors off a car that hadn't had a brake job in 13 years.
post #6 of 22 Old 04-10-2013, 06:00 AM Thread Starter
Quoted: 2 Post(s)
Sorry, should clarify the Tranny Remote Filter housing behind the Radiator.
May have to cut it off in pieces, soaked it in PB Blaster as I'm all out of AeroKroil will get another chance to break it loose tonight.
Used the Impact Wrench to no avail. and a 3' Cheater bar, nada.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #7 of 22 Old 04-10-2013, 06:10 AM
portcity_gt's Avatar
Quoted: 1213 Post(s)
The impact is going to be the best option, wrenching on it is just going to bend the bracket and mess up the lines.
But why are you only running 90 psi !?! Crank that thing up to 120, if your compressor will only do 90 that's your problem, that's not a big enough compressor for an impact.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #8 of 22 Old 04-10-2013, 08:57 AM
rdunagan's Avatar
yea impact is your best bet
rdunagan is offline
post #9 of 22 Old 04-10-2013, 10:03 AM
PGreenSVT's Avatar
What is the torque rating on your impact? Cheap ones don't really crank that hard.
post #10 of 22 Old 04-10-2013, 11:30 AM Thread Starter
Quoted: 2 Post(s)
I dunno it's a loaner. Big honkin gun type i'll try to run up the PSI on her.
I have another housing in will call and may just drill it and drain it then saw it off in pieces.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
