175/75/MTW Billet wheel dyno - Ford Powerstroke Diesel Forum
post #1 of 122 Old 04-09-2013, 05:51 PM Thread Starter
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Well i got to go to the dyno today after installing A MTW billet wheel on my powermax thanks to Adrian.
Dyno numbers before the wheel was 515/820 or 830 I don't have the sheet near me.
Dyno numbers today are
576.4/882
580/1012.6
581.3/1010
76 degrees with no heat soak
With all runs consistent. The change in tq was me changing fuel pressure.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #2 of 122 Old 04-09-2013, 05:53 PM
legionxxii's Avatar
Impressive gain on a wheel can you feel the difference
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #3 of 122 Old 04-09-2013, 05:54 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
The wheel alone made the truck accel with ease and it hits the mph alot faster. The wheel weights alot less then the stock pmax wheel. I got other stuff done to the truck too. The wheel makes my turbo spin FaSt!
Oliver
ODAWG714 is offline
post #4 of 122 Old 04-09-2013, 06:03 PM
bondajb's Avatar
What fuel psi did you find optimum?? Congrats.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #5 of 122 Old 04-09-2013, 06:06 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
Thx bud. Dropped to 55 from 62. During the run fuel psi stayed at 51 steady
Oliver
ODAWG714 is offline
post #6 of 122 Old 04-09-2013, 06:15 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
VERY NICE Numbers man.
Out of curiosity on the fuel pressure. I presume you have a RR kit?? I ask because I also felt a noticable gain in low end response/power when I dropped my fuel pressure from 62psi to 52psi. I also have a RR kit.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 122 Old 04-09-2013, 06:18 PM Thread Starter
ODAWG714's Avatar
Quoted: 6 Post(s)
Thx Nate. Ya my buddy made me a nice rr kit. I been driving with 62psi and the wheel made a big difference and I guess the truck likes lower fuel to match hpo I suppose
Oliver
ODAWG714 is offline
post #8 of 122 Old 04-09-2013, 06:19 PM
Wow. Good numbers. What other mods done? That's a nice gain for a $300 upgrade and only a couple hours of time
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #9 of 122 Old 04-09-2013, 06:20 PM
kTm520's Avatar
What should fuel pressure be ran at with the 6.0's? And whats the lowest it can drop until your hurting injectors?
2005 King Ranch, arps, oem gaskets, pmax, 190's/100's bu warren, egr delete, 5 inch exhaust, sct tuned by quick tricks/innovative/gearhead, suncoast trans, custom paint work work
kTm520 is offline
post #10 of 122 Old 04-09-2013, 06:20 PM
bondajb's Avatar
my psi was 72 with the blue spring. that is the reason I did a rr. running a constant 50-52 now. thanks for justifying this for me.
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
