Livewire ts problem - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-09-2013, 05:22 PM Thread Starter
Brent Beeler's Avatar
Livewire ts problem
Hey guys 07 F250 with the LiveWire TS It doesn't think I have the key in the ignition I've tried turning the auto detect to none And it comes up with an error see picture below what is the cure? Thanks in advanceLivewire ts problem-imageuploadedbyautoguide1365556920.291041.jpg
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 20 Old 04-09-2013, 05:29 PM
portcity_gt's Avatar
Quoted: 1456 Post(s)
Try to update it.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #3 of 20 Old 04-09-2013, 05:40 PM Thread Starter
The updater should be able to tell if it needs an update right?
post #4 of 20 Old 04-09-2013, 05:59 PM
Yep, just plug it in, it will prolly check on its own but you may have to click "check for updates".
post #5 of 20 Old 04-09-2013, 06:12 PM Thread Starter
Okay, thanks. I'll let you know what the outcome is.
post #6 of 20 Old 04-09-2013, 07:54 PM Thread Starter
My laptop doesn't detect the livewire I've updated the sct updater, still not connecting. Any ideas?
post #7 of 20 Old 04-10-2013, 05:30 AM
You'll prolly have to contact sct.
post #8 of 20 Old 04-10-2013, 05:33 AM
You can try this also.
Error: Device Communication Failed - SCT SupportSuite
post #9 of 20 Old 04-10-2013, 05:45 AM
at0075's Avatar
See this is why I think I've chose to go the handheld and edge route. Can it be manually turned on and off?
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #10 of 20 Old 04-10-2013, 06:42 AM
Just went through this with mine. If you look in the plug on the cable that goes into the side of the live wire can you see any of the little metal connectors bent back?
F350$PIT is offline
