Help ! Under the Truck Tranny Solenoid Swap??? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-09-2013, 04:06 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Which one controls the shift firmness or 3-5 Flare and which one fixes the Rev shutter
text if you want 972 841 3278
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 12 Old 04-09-2013, 06:07 PM
portcity_gt's Avatar
Quoted: 1218 Post(s)
That's the direct clutch solenoid, you will want to replace it with a epc solenoid.
The one you want to change is in the row closest to te rear end, it's the one in the center.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 12 Old 04-09-2013, 06:11 PM Thread Starter
Quoted: 2 Post(s)
I have 2 Sol's from MTS the instructions don't say which is which real vague, i'll include a pic of sols and instructions.
It appears to remove 2 and 6.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #4 of 12 Old 04-09-2013, 06:16 PM
Well I'm pretty sure the direct solenoid controls the 3-5 shift AND reverse. I'm nut sure what other one they sent you. If your supposed to change the epc solenoid I think you have to drop the wire harness and valve body.
post #5 of 12 Old 04-09-2013, 06:19 PM
There's some info and links in here.
Alternative to go-go soilinoid ??
post #6 of 12 Old 04-09-2013, 06:29 PM
pizza pig's Avatar
Denny
huh? rev shutter?
Direct solenoid is the middle in the row of 3 and is the solenoid you replace if you have shift flare on the direct. The EPC solenoid is underneath the solenoid body and controls shift pressures. This EPC can be used in the direct spot by turning it until it slides in all the way.
if thats what your asking?
pizza pig is offline
post #7 of 12 Old 04-09-2013, 07:08 PM
all good guys I got him took care of
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #8 of 12 Old 04-09-2013, 07:45 PM Thread Starter
Quoted: 2 Post(s)
Here the vague instructions..... MTS Provided Clear as used Tranny Fluid...
I have 2 Sol's as you can see and need to fix....
A. 3-5 Flare
B. Rev Chatter
Thoughts ?
Gary has helped tremendously.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #9 of 12 Old 04-09-2013, 08:05 PM
pizza pig's Avatar
You can clearly see on the packaging that one solenoid is for the direct or coast clutch and the other solenoid is for the torque converter clutch/ OD clutch/ or low-reverse clutch.
The one on the left goes in the direct slot (middle in the row of three)
Still trying to figure out wtf rev chatter is
post #10 of 12 Old 04-09-2013, 08:12 PM
pizza pig's Avatar
Im going to assume you mean reverse chatter. Just because It's the internet doesn't mean you shouldn't use punctuation.
Here is something that will help low/reverse solenoid is solenoid E
