Push rods worth it? - Ford Powerstroke Diesel Forum
post #1 of 64 Old 04-09-2013, 06:49 AM Thread Starter
Like a boss!
Laferty's Avatar
Push rods worth it?
Hey. Wondering everyone's opinion on if I should upgrade my pushrods. Is it a worthwhile expense or will it not improve longevity or reliability. And when I look at the pictures of them for sale they are in sets of 8... is that just the pick or do they come in sets of 16? I am getting 155/stock injectors and FICM fixed and tuned with a atlas 40 tune. Doing head gaskets, blue spring, BPD oil cooler and a SCT tuner to be first used when/if I put it on the dyno.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #2 of 64 Old 04-09-2013, 07:05 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I bought a set of Smith Brothers 3/8in pushrods and I can say that they were worth every penny of $287 shipped. They came as a set of 16. The stockers do not even come close to comparing how beefy these pushrods are. I am totally convinced that I will break a rocker arm or collapse a lifter before one of these b!tches bend. Basically, if one of these bend, I'll have bigger problems than a bent pushrod for sure.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 64 Old 04-09-2013, 05:06 PM
kcoyner's Avatar
Quoted: 74 Post(s)
Exactly right! When you look at high performance engines these days that are built by people who really know what they are doing, you'll likely see BIG push rods.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #4 of 64 Old 04-09-2013, 05:11 PM Thread Starter
Like a boss!
Laferty's Avatar
I suppose it is worth the dollars. I am not pushing big power but it will be one less thing I have to worry about. Where did you purchase your rods? The only place I see smith brothers rods is on riffraffdiesel but it doesn't give any specs on them.
2006 CCLB
Laferty is offline
post #5 of 64 Old 04-09-2013, 05:24 PM
BACKYARDIGAN
Quoted: 4 Post(s)
I ordered mine strait from Smith Bros. I just ordered the "stock" 6.0 length spec, which I believe is 9.850 but don't quote me on that.
Nate
post #6 of 64 Old 04-09-2013, 05:27 PM Thread Starter
Like a boss!
Laferty's Avatar
Did you have to modify the headgasket holes due to the bigger rods passing through them?
2006 CCLB
Laferty is offline
post #7 of 64 Old 04-09-2013, 06:09 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Nope. The 3/8" pushrods slide right in with no modifications at all.
Nate
post #8 of 64 Old 04-09-2013, 06:09 PM
the ones on riff raff are the ones you want and no you do not have to modify the head gaskets
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #9 of 64 Old 04-09-2013, 06:13 PM Thread Starter
Like a boss!
Laferty's Avatar
Thx for the help guys.
2006 CCLB
Laferty is offline
post #10 of 64 Old 04-09-2013, 08:49 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Quick question. Do you guys know any one who has bent push rods? I ask because Ellerton's 1000hp truck uses stock pushrods IIRC. The only guy I have seen bend push rods did so in a 7.3 while downshifting on a steep grade towing over 15k lbs.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
