Aluminum Degas bottle - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-08-2013, 05:18 PM Thread Starter
brscott38's Avatar
I am wanting to build an aluminum degas bottle but want to use the stock cap. Does anyone know where I can find the threaded bung the cap screws on to? Ford uses the same cap on the mustang and others. I have looked all over and can't find anything does anyone have suggestions. There are ones for mustangs but no one seems to sell the threaded piece.
Sent from my SPH-L710 using AutoGuide.Com Free App
brscott38 is offline
post #2 of 6 Old 04-08-2013, 06:00 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Might wanna check out www.cantonracingproducts.com
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 6 Old 04-08-2013, 06:11 PM Thread Starter
brscott38's Avatar
That looks nice. Can I get away with any cap that is 16psi.
post #4 of 6 Old 04-08-2013, 06:15 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
The stocker is 16psi, so why couldnt you get away with it?
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #5 of 6 Old 04-08-2013, 06:20 PM Thread Starter
brscott38's Avatar
That's what I was thinking but it seems that I have heard to stay with a ford cap
post #6 of 6 Old 04-09-2013, 12:25 AM
strokin6L's Avatar
Quoted: 4 Post(s)
You can use any 16 psi cap. The guy who is running the tank I pictured has a radiator style cap and works just fine. Just make sure its 16 psi rated
