Fuel system from turbo car swapped to truck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-06-2013, 04:12 PM Thread Starter
I have this fuel system on my turbo car and was wondering if it can be used on my truck.... 05 6.0 f350
Fuel-injection with Fixed Pump Head for 1,000+ hp
Thanks,
Ray
rtkjadams is offline
post #2 of 5 Old 04-06-2013, 04:16 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I don't see why not. What's the pressure rating on? Is the pump compatible with diesel?
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 5 Old 04-06-2013, 05:02 PM Thread Starter
Max pump output is 120 psi, not sure if pump is compatable with diesel fuel or not....
Ray
post #4 of 5 Old 04-06-2013, 06:36 PM
Quoted: 10 Post(s)
Well, that's going to be the big question, whether it will work with diesel. If so, it appears it would be sufficient.
Shack
post #5 of 5 Old 04-06-2013, 08:02 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
If you want to use that pump on your truck, I would recommend tossing the pre and post pump filters and put a spin on water separator pre-pump and a spin on 2 micron filter post pump. I'm going to say that most pumps out there will work with diesel fuel as it has a much greater lubricating capacity than gasoline and alcohol fuels do. That is a VERY expensive pump. Looking at the specs, it looks like it should do the job.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
