dual fuel pump system - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-06-2013, 03:47 PM Thread Starter
has anyone every tryed this, like feeding each head with its own pump and reg them off the rear with a single return?
03 CCSB 6.0 -built not bought-
Motor - Under construction
compounds/built bottom end
sponsored by Streetdieselperformance.com
ac540 is offline
post #2 of 14 Old 04-06-2013, 04:10 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Read this thread......
Dual stock fuel pumps...Is it possible?
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 14 Old 04-06-2013, 05:12 PM
pizza pig's Avatar
Sounds like a giant waste of money with no benefit.
pizza pig is offline
post #4 of 14 Old 04-06-2013, 09:58 PM Thread Starter
greg i know it does sound that way but was just thinkn cuz u c people dual pump like when running 2 cp3's so idk was just thinkn
ac540 is offline
post #5 of 14 Old 04-07-2013, 04:28 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Originally Posted by ac540 View Post
...was just thinkn cuz u c people dual pump like when running 2 cp3's...
First off nothing wrong with thinking outside the box. Unfortunately though, what you are proposing will have no benefit whatsoever my friend and here's why. The OEM fuel pump (/HFCM as some people call it) is only responsible for filling the injectors with fuel to be injected into the motor. The High Pressure Oil Pumping System is what is responsible for actually injecting the fuel into the motor via hydraulic oil pressure. CP3 pumps do both filling the injectors and injecting the fuel into the motor. However, the common rail injection system is vastly different from our injection system. What you are actually thinking of (and kind of applies) is dual High Pressure Oil Pumps (HPOPs). These provide more oil flow to the injection system and in essence is the closest thing you can do on motors that would be like a dual CP3 setup. However though, you wouldn't really see any gains unless you were running (at a minimum) a 190/100 or 205/100 injector. Basically, for 225s and above, you could possibly look into something like this. Either way though, higher injection pressure does give better atomization of the fuel for a better burn and more power. Hope this helps some.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 14 Old 04-07-2013, 10:29 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
I'm just going to throw this out there for consideration. After seeing the data and dyno sheets that Bill @ PHP posted up after installing the HPODS system on his truck there is no doubt that the extra HPO makes a considerable difference in the higher rpms. And that was on a 175/stock nozzle setup. So here is my thought on it. It will come as no surprise for those who have seen my posts on the subject of nozzles that I think most people run nozzles that are too large for the injector i.e. 190/100 or 175/75. etc. I think that the large nozzle makes up for a lack of HPO required to inject the fuel at high rpm. So the additional HPO really allows you to get the best high rpm injection with the smaller nozzles whether through dual HPOPS or the HPODS setup. The advantage being a better torque curve throughout and no loss of high rpm fuel delivery because of the smaller nozzles.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #7 of 14 Old 04-07-2013, 10:36 AM
pizza pig's Avatar
the fuelab 41401 I use is good for 1000 hp. Doesnt even move the fuel pressure gauge at 60psi with 225's and 100% nozzles. More than sufficient for any 6.0 build. Oiling system is the issue with these trucks. You know that already Tyler.
I know what youre getting at, however, not like a common rail there is no need for dual "low pressure" fuel pumps to supply the demand and volume needs of dual pumps (dual modded/tripple pumps) and big nozzles
post #8 of 14 Old 04-07-2013, 01:43 PM
PGreenSVT's Avatar
As said in the linked thread separate pumps feeding each head leave you with a situation where one pump could die leaving you with fuel to only one side of the engine. It's just not a good idea.
post #9 of 14 Old 04-07-2013, 06:56 PM Thread Starter
well heres the thing im going 350/150's so i am things there gunna be thirsty lol so idk eichner and i were just throwing some ideas around u know deff going with jess's dual pump set up he hooked me up with one for this build
ac540 is offline
post #10 of 14 Old 04-07-2013, 06:57 PM Thread Starter
nd yeah i deff know that for sure so i mean i was thinking about changeing it up for more fuel for sure
ac540 is offline
