I'm New, Little Help w/ SCT + Edge Insight - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-05-2013, 09:51 PM Thread Starter
Broke 20's Avatar
Quoted: 7 Post(s)
Hello diesel folks. Let me start by saying I am completely new to this world and know almost nothing about it. I recently purchased an 04 250 with a few light modifications. The truck already had an Edge Insight installed, which I really like, keeps close monitoring on everything and provides good piece of mind. I bought an SCT x3 from a guy at work wanting to get a bit more out of the truck. I unplugged the Edge, let the SCT do its thing, and plugged the Edge back in. Now, the Edge seems to have forgotten everything. It doesnt even give me options anymore for a boost psi gauge, TFT, Oil temp, EGT along with a few others. From the setting I had before, it only retained my ECT gauge and average mpg's. My apologies if this is a noob question, but any help is appreciated.
Thanks
Jeremy
Broke 20 is offline
post #2 of 7 Old 04-06-2013, 12:29 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Yep I had the same issue.It has been a while so I can't exactly remember the fix ,as there are some old threads out there on this topic.If memory serves me its something with reading the Vin ID of the truck and this was only and issue with 03-04 models. I would first make sure you have the latest update on the insight.When I get a chance I will try to find
the older threads and I am sure others will chime in.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #3 of 7 Old 04-06-2013, 12:36 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
One more thing ,when you plug in the insight does it show the vin or ask you to enter it?
post #4 of 7 Old 04-06-2013, 06:43 AM
USAFBowman's Avatar
I would take it out and try to update it....
USAFBowman is offline
post #5 of 7 Old 04-06-2013, 02:35 PM Thread Starter
Broke 20's Avatar
Quoted: 7 Post(s)
I updated the Edge as soon as I brought the truck home probably about two weeks ago. I will try again and see if it helps. And the Edge no longer recognizes the ecu. When I set it up again after the SCT flash, it asked the make/fuel type/motor size during startup. I will do some searching as well and see what I can find, I appreciate your help.
Jeremy
Broke 20 is offline
post #6 of 7 Old 04-06-2013, 08:18 PM Thread Starter
Broke 20's Avatar
Quoted: 7 Post(s)
I found a few older threads that you may have been talking about, but most of them are from the '09-'10 time frame and dealing with a previous model Insight. I updated the Insight CTS again tonight, and I am going to play with the SCT tomorrow. If I cant get anything figured out, going to try making some phone calls Monday morning to figure out whats wrong.
Broke 20 is offline
post #7 of 7 Old 04-07-2013, 01:15 PM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Why don't you take the tune off,then see if the cts shows the pids.
