SCT + Guages or SCT Livewire? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-04-2013, 08:34 PM Thread Starter
Question SCT + Guages or SCT Livewire?
Straight forward, i will be getting an sct by the end of this month, and am just wondering what would be a smarter path to take. Sct with guages (egt, boost, etc.) or livewire with its digital display monitoring. How accurate is the livewire compared to guages? obviously the livewire has many more features than the straight up handheld which would come in handy at some points, but what would be the safest way to go?
Hidalgo5435 is offline
post #2 of 12 Old 04-04-2013, 08:40 PM
sprksonu's Avatar
Livewire all the way you can monitor 9 pid's at one time I have one and love it
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 12 Old 04-04-2013, 09:09 PM Thread Starter
thats what im leaning on too, only downside is the egt probe kit which has been discontinued everywhere i look, and then theres the "wiring harness" for that probe kit too for it all to function, which is another $100+
post #4 of 12 Old 04-05-2013, 07:06 AM
sprksonu's Avatar
Bullet proof diesel has the 9617 egt kit in stock give them a shout
sprksonu is offline
post #5 of 12 Old 04-05-2013, 07:25 AM
mackattack6.0's Avatar
I think xdp or sinister came out with a probe that is compatible with the livewire ts
'03 6.blow F250 CCSB lariat, ARP Studs, Ford Gaskets, New Oil Cooler 75k, XDP EGR Delete, SCT Livewire TS with Looney Wild from Vivian, MBRP 4" straight pipe, Blue Spring Update, Zoodad Mod, High Idle, Fog Light Mod, 73,XXX
mackattack6.0 is offline
post #6 of 12 Old 04-05-2013, 08:49 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Through the research I have done. It is cheaper in the end to get a live wire because getting nice gauges can run u a fair amount of money plus then with a programmer seperate its even more just my thought.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #7 of 12 Old 04-05-2013, 10:18 AM
Chatham036's Avatar
Quoted: 151 Post(s)
SCT + Guages or SCT Livewire?-imageuploadedbyag-free1365185742.138081.jpgSCT + Guages or SCT Livewire?-imageuploadedbyag-free1365185753.885065.jpg
Here is a couple pictures of the SCT Livewire. I run the insight CTS and x3 combo but wanted to use this Livewire to gain familiarity to assist our customers. Pretty nice device all and all. I have been using it for 3 days now
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #8 of 12 Old 04-06-2013, 09:33 PM
thanks for the pictures i was curious what it looked like installed and operating, looks great!! better add it to my list of things to do.. haha
lrgnugs is offline
post #9 of 12 Old 04-06-2013, 09:54 PM
Dave at BCDiesel.ca's Avatar
Quoted: 4 Post(s)
I am starting to sell more of the SCT Livewire for the 6.0L, even starting see Mini Maxx sales going up but I still sell and install 10 to 1 Custom tuned SCT X3's with the Edge Insight CS or Insight CTS display.
The Insight monitors some critical parameters easily view-able, user friendly with easy set alarms. It accurately displays the usual Pyro, Boost and trans temp with a sensor for pyro. Equally important on the 6.0L it monitors EOT (Engine Oil Temperature) and ECT (Engine Coolant Temperature) on the powerstroke which can pre-warn a failing oil cooler before it fails all together. Also the Insight reads Battery Voltage and FICM (Fuel Injection Control Module) all vital pids we monitor with our Ford IDS software when diagnosing a 6.0L Powerstroke.
Dave at BCDiesel.ca is offline
post #10 of 12 Old 04-21-2013, 08:14 PM
valhalla1's Avatar
I was searching looking for posts on this stuff, I am leaning toward the livewire for the monitoring and tuning aspect...but I do have to be able to get the egt probe for it I am very interested in as much info as you guys can give!!
valhalla1 is offline
