Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #11 (permalink)
Old 03-13-2008, 06:56 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
Originally Posted by rageingbull View Post
were does the stock file come from? is it in the x3 from your truck than you just save it or do you have to do somthin to get it- sorry just got my tunes and i am very unsavey when it comes to computer stuff
The X3 removes it from your truck when it downloads the new one. Just connect your X3 to your laptop and copy it to your hard drive...
  #12 (permalink)
Old 03-16-2008, 05:23 PM
MOMBENZ MOMBENZ is offline
Thank you Terry
rageingbull, feel free to call us and we'll help you with it.
Thanks,
Vivian
  #13 (permalink)
Old 07-02-2008, 12:15 PM
snoboy snoboy is offline
Just to make sure I did it right. OK I down loaded stock using "get stock file" I then saved it in "My Albums" and appears as 2 folders "flash file" and "stock file" is this correct?. If I want to see them I push transfer file and then they show up as 2 files stored in my albums. BUT they do not appear on the page with all of my custom tunes, is this correct?
I just want to be sure the stock file is saved.
Thanks
  #14 (permalink)
Old 11-05-2008, 08:28 AM
bigct59 bigct59 is offline
Stock file saved on PC
So if you save the stock file to the PC can you still return your truck to stock the same as if you had just left it on the X3??
  #15 (permalink)
Old 11-05-2008, 08:46 AM
It's my understanding that...The truck should be always be returned to stock when making file transfers from X3 to PC, this way if X3, PC or USB cable accidently craps out the stock file will not be lost.
  #16 (permalink)
Old 11-05-2008, 11:43 AM
Yea..my question is after you save the stock file to your PC , then you program your truck, what is the next step to return your truck to stock after it has been programmed??
  #17 (permalink)
Old 11-05-2008, 09:37 PM
Even though you "tune" the truck, "return to stock" is always an option on the X3. It appears on the same screen as "load tune".
