175's with stock fuel and turbo - Ford Powerstroke Diesel Forum
post #1 of 44 Old 04-03-2013, 03:17 PM Thread Starter
dpmac83's Avatar
Has anyone ever done this?? Is it possible and what would I break first??
05 F250 CCSB Lariat 3" level with 35x12.5R20 Toyo Open Country MT
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
MRBP 4 in turbo back
CTS Monitor W/egt
Coolant filter w/ CAT ELC
FICM replaced
STC replaced
HPOP replaced
IPR replaced
$$$Looking at this list makes me want to sell my truck!$$$
dpmac83 is offline
post #2 of 44 Old 04-03-2013, 03:49 PM
Marine Raiders>Seals
najaf4life's Avatar
You can do it. Just make sure you get a tune built for it.
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #3 of 44 Old 04-03-2013, 04:34 PM Thread Starter
dpmac83's Avatar
thanks for the help, I have a set of 155's on order but was talking to someone today who suggested 175's, what size nozzle should I go with?
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
post #4 of 44 Old 04-03-2013, 04:48 PM
colonel angus's Avatar
Quoted: 2 Post(s)
What are your long term plans? Do you mind working on it and doing the work yourself and building it up as you go? If not each step will require different tuning to run optimally, just keep that in mind.
30's cover just about everything you need, unless you need more.
D
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #5 of 44 Old 04-03-2013, 05:01 PM Thread Starter
dpmac83's Avatar
Well I am going to do injectors in the next week or 2, after that I will be doing Turbo and fuel when i round up the funds and time, then the plan is to build a trans to go into it. The truck is quickly becoming my toy instead of my daily driver which is fine with me, I should be inheriting my wifes car when she gets a new one. I understand that i would be needing tunes for each step but I feel like that would just be cheap insurance for the truck. And yes I plan on doing everything myself with the help of you all of course!
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
post #6 of 44 Old 04-03-2013, 05:06 PM Thread Starter
dpmac83's Avatar
I am worried that If i go with 155/30's that I will be wishing i had gone bigger
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
post #7 of 44 Old 04-03-2013, 05:16 PM
Go 175\30, you'll be able make them work with your stock parts for now with proper tuning, then you can build on them later. At least a blue spring upgrade or a regulated return setup would be wise to protect your new injectors.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
The Following User Says Thank You to slvr bullet For This Useful Post:
Dts327 (08-13-2014)
post #8 of 44 Old 04-03-2013, 05:18 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
I have 175/stock injectors and I love them. I'm upgrading to 175/75 only because mine are being replaced cause of some cold start issues. As mentioned earlier, the underlying goal of the truck will dictate what you opt to go with. You can run 175cc injectors with a stock turbo and transmission and not have to worry about breaking something too bad because you're not overdoing the truck at the point...as least that's my $0.02. 175's will give you great power, my mpg's went up 3-4 depending on how I drive and I'm currently running a stock turbo/trans.
Just ask yourself: Am I trying to make 600+ hp or do I wan't a fun reliable toy?
That's gonna dictate the injector you go with. Also talk to the injector builders and seek their advice/opinions. I talked to both Jesse and Sheldon and based on the intended use of my truck, they virtually suggested the same injector.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #9 of 44 Old 04-03-2013, 05:23 PM Thread Starter
dpmac83's Avatar
I have done the Blue spring already and Can get with Wildman again about tuning the truck to run the 175's. I will have to call Warren tomorrow and see if they can make my nozles 175 instead of 155. I am starting to get really excited about the way this is going.
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
post #10 of 44 Old 04-03-2013, 06:18 PM
Quoted: 2 Post(s)
175/75's are difficult to tune for everyone, I know I've tried a lot of 'em.
As has been said in numerous posts about injectors, go with a consistent bump in injector body and nozzle to be able to tune correctly... I.E. 175/30 190/50 I believe.
It does you no good to have a nozzle bigger than body and try to tune around it.
Each truck is different as is each drivers sensitivity to driving scenario. I.E. what one guy feels is perfect is barely acceptable to another.
My hybrid w stg 2 wheel cannot clean up 175/75's with Viv or Eric's Tunes, Tony can clean it up but you can tell it's not near as strong. I'm not saying Tony couldn't tune it to match the #'s of the others but it would be as smokey as theirs too.
I"m waiting on a set of 175/30's with hopes it will feel just as strong since it will be tuned optimally and the Tq and Hp as well as MPG be perfect.
If it was me i'd search the forum for injectors and read the 90+ pages of info. and know what I wanted before making a decision you likely won't be happy with and will end up doing it all over again, again and again.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
