100psi fuel pressure!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-02-2013, 04:23 PM Thread Starter
licenced2burn's Avatar
My freind bought a 03 f250 a month or 2 ago and we did an egr delete and new oil cooler. And he replaced all the fluids and filters and ever since he changed the fuel filters which was about 2 weeks after the egr delete and oil cooler. It has been hard to start in the morning. It will take 2-3 tries to get it going. So I told him I wanted to check the fuel pressure so we put my pressure sensor for my edge on his truck and the psi when he turned the key on was 92 and after he started it then it went to 100 and maxed out the sensor. I know that's bad to have that high of pressure what what could be causing this? I would think it would have to be the regulator. The psi was taken from the test port by the regulator.
Tony
2005 F250 crew cab lariat,
4" lift 325/65/18 tires, head studs, built trans, egr delete, powermax turbo, 58v ficm from swamps with mild flash, 4" straight pipe, sct with innovative xtreme street and race tune's, blue spring upgrade
Stage 3, 190/100 injectors, and full fuel system on the way.
licenced2burn is offline
post #2 of 4 Old 04-02-2013, 04:26 PM
wvrrcarknocker's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Could be one of those "Other" fuel pressure regulator springs. Might just need a Ford spring.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #3 of 4 Old 04-02-2013, 05:35 PM Thread Starter
Yeah that could be. I'm still wondering if this has anything to do with the hard starts. The ficm is healthy and the hpop seems healthy according to what the cts reads. But it starts and dies a couple times before It will run.
Tony
post #4 of 4 Old 04-02-2013, 05:46 PM
Powerstroke Techie
Lilpooh's Avatar
Troubleshooting a No-Start condition
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
