EGR/oil cooler; How many hours? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 04-02-2013, 08:01 AM Thread Starter
localboy's Avatar
How long, in hours total to remove & replace? Trying to get an idea how much it would be in labor.
Watched the entire procedure on Youtube; it's pushing the limits of my skill set and I just don't have the time to do it. I will probably have to replace both in my '05; the deltas are up to 19*F when towing our boat. Going to use the Sinister kit since we have emissions testing here.
Thanks for any input
Aloha...
"Eddie would go..."
2005 F-250 Superduty XLT short-bed
6.0 diesel crew cab 4X4
Sinister upgraded EGR kit
Performance Machine coolant filter kit
Scangauge II
Upgraded FICM
...other than that, bone stock
localboy is offline
post #2 of 22 Old 04-02-2013, 08:24 AM
It took me 4 hours for disassembly at a comfortable pace with fairly simple hand tools. Mines still apart waiting on new parts but I can assume another 4-5 going back together. Granted I wasn't rushing and made sure I was inspecting all the parts as I tore it down so I'm sure it can be done faster but I'm sure a shop will at least charge you 8 hrs minimum to do the job.
BobD981 is offline
post #3 of 22 Old 04-02-2013, 08:44 AM
rdunagan's Avatar
shops will charge anywhere from 6-8 hours for one. i normally charge 8 but i do more than the average bear as well. clean all the parts and what not
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #4 of 22 Old 04-02-2013, 10:30 AM Thread Starter
localboy's Avatar
OK. Thanks. I'm lookint at 6-8 hrs at $100/hr plus parts. F'infantastic....
Any opinions on the Sinister kits? Good? Bad? Is there another emissions approved kit I'm not aware of? I assume it's smart to change the EGR at the same time as the cooler, since it will be all apart anyway and if the cooler failed the EGR is next. (I had a new cooler installed by the dealership in 2008 under warranty and wished I had installed a filter kit then).
Aloha...
"Eddie would go..."
Scangauge II
Upgraded FICM
localboy is offline
post #5 of 22 Old 04-02-2013, 11:30 AM
I understand the bulletproof diesel kits are the standard but sinister seems to be right in there as well. I went with performance machine myself but I did the delete, not a new cooler.
BobD981 is offline
post #6 of 22 Old 04-02-2013, 11:51 AM
Quoted: 52 Post(s)
I was quoted 11 hours for the delete and OEM oil cooler replacement but that's for a van.
05 E350 4x4 6.0 99k: DC Power XP250A, Dieselsite coolant filter, ELC coolant, IPR GEN2 EGR delete, KCturbo Stage 1.5, updated turbo drain tube/oil feed line/STC fitting/OEM oil cooler, cat delete, high-flow muffler, SCT Tuner with IDP Xstreet tune, PHP Atlas 40 FICM tune, Blue Spring, billet fuel filter cap, BPD water pump, Scanguage II, AutoMeter fuel pressure and pyro gages, Tru-Cool Max 40,000 GVW transmission cooler
6.0vanman is offline
post #7 of 22 Old 04-02-2013, 12:08 PM
rdunagan's Avatar
vans are a TERD!!!!!!!!!!! check out the IPR egr delete kit top notch kit!
rdunagan is offline
post #8 of 22 Old 04-02-2013, 12:10 PM
Quoted: 52 Post(s)
I prefer "Beast" thank you
I'm only at 7 to 9 on my deltas but when the time comes I going to do the IPR GEN2 kit.
post #9 of 22 Old 04-02-2013, 12:20 PM
rdunagan's Avatar
lol sorry i ment to work on!
rdunagan is offline
post #10 of 22 Old 04-02-2013, 04:32 PM Thread Starter
localboy's Avatar
I need it to be emissions approved. We have to do an emissions test every two yrs up here in the PNW. That's why I was considering the Sinister kit. It was the only such kit I've found, but I am not an expert in this diesel crap.
HTML Code:
http://www.mkmcustoms.com/ford60lpowerstrokebasicsolutionwithupgradedcooler.aspx
Aloha...
"Eddie would go..."
Scangauge II
Upgraded FICM
localboy is offline
