HELP!! big problems! - Ford Powerstroke Diesel Forum
post #1 of 31 Old 04-01-2013, 04:27 PM Thread Starter
tekemp's Avatar
Well ill start by saying my friend and i pulled the cab off of his truck because his heads were starting to go, so while it was down he got the following parts:
Airdog ll
reg. return
58v FICM
upgraded turbo
head studs
190/75 injectors from warren diesel
and some misc. parts all factory ford gaskets
well once we got everything put back together the truck started very easy because of the fuel system didnt have to worry about air. It ran great for a day and a half just driving easy, he wasnt romping on the truck yet. Pulled out of the store and the truck shut off, well we got it back to the shop and pulled the filters off the air dog and they were empty so we filled them up turn on the key and the pump runs gets fuel psi up to the regulator(can see on the gauge) crank and the truck fires right up runs a little rough for about 5 sec and shuts off so basically the air dog is not pulling fuel from the tank for some reason. There is fuel in the tank and the line is clear we blew through it and heard it bubbling.
The other problem is now when it does start for a couple seconds its puking this "black fuel" out of the turbo up pipes right where it clamps to the turbo.
Im thinking this has got to be an injector problem but any thoughts would be greatly appreciated!!
Thanks!!
2012 F-350 CCLB XLT/EGR/WEATHERTECH/RIGID/CTS/
tekemp is offline
post #2 of 31 Old 04-01-2013, 06:02 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Man just do a quick search on the ADII here. The thing is a POS and Pureflow ought to be put out of business. Your friend threw his money away.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 31 Old 04-01-2013, 06:27 PM
nordstrom's Avatar
Quoted: 2 Post(s)
Here is an active thread for your friends un-delight
the AD2 nightmare continues
Not sure what would cause the fuel the end up in the turbo up-pipe but i am sure someone will chime in
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
post #4 of 31 Old 04-01-2013, 06:58 PM
fass seems to be a nice option on the fords
cfd_shop is offline
post #5 of 31 Old 04-02-2013, 01:54 AM Thread Starter
tekemp's Avatar
Well I certainly wish I would have done a little more research before going with the AD. I figured it was good being as innovative recommended it. Anyone have any thought as to why I'm getting all this fuel blowing out of the up pipes? Any chance it could just be residual unburnt fuel from the larger injectors?
tekemp is offline
post #6 of 31 Old 04-02-2013, 02:02 AM
the chad's Avatar
I'm pretty sure if that was fuel it would be hydro'd by now. And most of the time if your getting that much dueling into the cyl it's gunna be dumping straight white smoke.
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #7 of 31 Old 04-02-2013, 02:13 AM Thread Starter
tekemp's Avatar
It was smoking a good bit white when it did start and slightly rough to turn over for that first crank when it did start.
tekemp is offline
post #8 of 31 Old 04-02-2013, 02:16 AM Thread Starter
tekemp's Avatar
What else could it be though other then fuel?
tekemp is offline
post #9 of 31 Old 04-02-2013, 07:52 AM
the chad's Avatar
Did you pull the turbo to do the inj for any reason?
Chad
07 F250
ARP's with OEM
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
the chad is offline
post #10 of 31 Old 04-02-2013, 08:07 AM Thread Starter
tekemp's Avatar
Yes it's a brand new "stage two" garret turbo from innovative
tekemp is offline
