Bd power tq convertor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-30-2013, 08:23 PM Thread Starter
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Anyone have any luck with the bd power torque convertor?
Pros?
Cons?
Thx
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #2 of 6 Old 03-30-2013, 08:27 PM
1fastTRX's Avatar
Just get a PI converter... pog!
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #3 of 6 Old 03-31-2013, 11:16 AM
TurboStroker06's Avatar
on a aftermarket TQ converter would you generally go to say 2000rpm stall to bring the engine online sooner?
TurboStroker06 is offline
post #4 of 6 Old 03-31-2013, 11:42 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
It all depends on the type of turbo you use. Non-VGT turbos seem to do better with like a 2200+ stall and VGT turbos seem to like 1800- rpm stalls. It's all in the application that it is being used in.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 6 Old 03-31-2013, 11:55 AM
I would like to do 155 injectors and a turbo upgrade Like MTW stage 1 w/ billet wheel
that's why I was thinking 2000 stall
post #6 of 6 Old 03-31-2013, 12:30 PM
BACKYARDIGAN
Quoted: 4 Post(s)
For all intents and purposes, you're going to want to stick with the stock stall speed, which I think is around the 1800-2000 rpm range.
Nate
