155's and stock head bolts - Ford Powerstroke Diesel Forum
post #1 of 52 Old 03-30-2013, 07:51 AM Thread Starter
Rjstepp's Avatar
My trucks been down since mid january with injector issues, been pricing them out and 2 reman's will only be a little cheaper than a set of 155's with stock nozzle's(renagade $600). Head studs will still be on the to do list, but just can't afford to do both right now. Question is do I really need head studs at the moment if I have Matt tweak my srl for the 155's without being studded? studds may be anywhere from a couple of weeks to a month or more depending on how much ot I can get at work.
Rick
2003 F350 cclb 6.0l 126,000 miles
SCT X2 running matt's srl
edge insight cs, egt probe
egr delete
Sinister coolant filter
4" turbo back diamond eye exhaust
smoked cab lights and mirror lens
Cut '05 grille and rhino lined bed
Leveled on 35" toyo m/t's
Rjstepp is offline
post #2 of 52 Old 03-30-2013, 08:08 AM
legionxxii's Avatar
Someone on here was running 190s on stock bolts i want to say Pizza Pig but I could be wrong
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #3 of 52 Old 03-30-2013, 08:58 AM
The Silent Service
colo_dually's Avatar
Quoted: 12 Post(s)
I really caution folks running heavier injectors on stock bolts. To be honest you won't see any power gain on the upper end with the stock nozzles. Simply can't inject the full injector charge with the short pulse width. On that note, you're plan isn't too far fetched.
I would look at other injector manufactures and make sure you know exactly what you are paying for.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 52 Old 03-30-2013, 09:43 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Dude if your at the injectors you at the head bolts. Pull them one at a time and replace with ARPs, second best option to pulling heads off, but better than running without. Once you that far into engine it's only an extra hour or two to install ARPs one at a time. Few good write ups on here about doing that. Just a thought.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 52 Old 03-30-2013, 09:50 AM
jmeaby's Avatar
Quoted: 16 Post(s)
I asked a while ago about doing studs one at a time and ppl said that is half *** and not to waste my time or pay for someone to do that. Just saying. Has the view on that changed I know some magazines have been talking about doing it so just wondering
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #6 of 52 Old 03-30-2013, 10:05 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Doubt anyone's opinions have changed, but I think most agree its the second best option, better than not doing it. Lots of people running after the one-by-one method without issues. Don't over complicate it, think of it in simple terms. If your heads are not leaking now, the application of more clamp down power of studs ain't going to hurt anything. It's a known fact that if you have head gasket issues, doing the one at a time method surely won't fix anything
post #7 of 52 Old 03-30-2013, 10:34 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Ok so if you don't have problems now you shouldbt but if somethings on its way out its nor stopping it, but its better then stock head bolts.
04 f250 cc sb.
jmeaby is offline
post #8 of 52 Old 03-30-2013, 10:51 AM
Dirty_Stroke's Avatar
OP, I think you will be fine. I ran my 155's with stock bolts for 5 months or so before doing studs. The truck DID end up blowing coolant out the degas bottle right before I put the studs in but no problems as long as I wasn't WOT. I could have made the stock gaskets last perfectly fine if I didn't drive this thing like a bat out of hell.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #9 of 52 Old 03-30-2013, 11:19 AM
DoubleDpsd's Avatar
If they lift with stock injectors why would they not lift with larger than stock injectors?
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #10 of 52 Old 03-30-2013, 01:26 PM Thread Starter
Rjstepp's Avatar
Funds is the issue, not enough to get the studs right now. Was planning on doing them one at a time. Big thing is I've been down to one vehicle between me and my wife since early january, trying to get it toware I can drive it back and forth to work until I get the funds for studs.
Rick
egr delete
Rjstepp is offline
