6.4 banjo's Good or bad?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-27-2013, 02:40 PM Thread Starter
dpmac83's Avatar
Last i heard everyone was dicussing whether 6.4 banjo's were good for the 6.0. Was there ever a conclusion or is it still just opinions?? I was wondering if i should look into them for my truck?
05 F250 CCSB Lariat 3" level with 35x12.5R20 Toyo Open Country MT
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
MRBP 4 in turbo back
CTS Monitor W/egt
Coolant filter w/ CAT ELC
FICM replaced
STC replaced
HPOP replaced
IPR replaced
$$$Looking at this list makes me want to sell my truck!$$$
dpmac83 is offline
post #2 of 11 Old 03-27-2013, 03:08 PM
powerstrokecrzy's Avatar
Quoted: 255 Post(s)
I think there is still mixed opinions. Personally I look at it as less restriction so therefore better flow. Had mine in for probably 15000 miles with no known problems. FWIW
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #3 of 11 Old 03-27-2013, 03:08 PM
portcity_gt's Avatar
Quoted: 1393 Post(s)
Neither. If you have it apart and feel like spending the $10 on them go for it. If not dont bother.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 11 Old 03-27-2013, 03:35 PM
Joeshu1000's Avatar
I put mine in went I did my head studs. Probably wouldn't have done it otherwise..
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Rudy's Cold Air Intake
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #5 of 11 Old 03-27-2013, 04:37 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
When you look into the fuel lines from the filter can to the heads you will find that the true restriction is in the banjo fitting itself. the orifice in the fitting allowing fuel into the banjo fitting is only 3/16". Nothing you do with the bolt will fix that. To really get more fuel into the head you need to scrap the banjo setup altogether and install M12 to -6AN elbows. That will give you a real open flow into the head. Of course it really helps to have the rest of the fuel system required to make this worth while.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 11 Old 03-28-2013, 04:12 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Had a set on my shelf for two teardowns of my engine, last year for ARPs, this year for injectors. Still haven't taken them off shelf!-lol. Can't justify why? Ford put the check valve there for some reason I guess - and with the blue spring mod, even my 155/30s never see below 58psi on a tow tune. That's measured at filter test port - I doubt I will ever install them. I don't think anybody has had issues after installing them though, nobody has posted issues on here.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 11 Old 03-28-2013, 04:56 AM Thread Starter
dpmac83's Avatar
Thanks everyone, I am doing injectors and was curious if it was worth it. I think i am going to pass.
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
post #8 of 11 Old 03-28-2013, 05:09 AM
I've had the 6.4 bolts for about 30k without any issue that I know of. But I do know for updated the spring for the check valve to a heavier spring for more seat pressure. I would say they did that to fix some issue but what I don't know. I personally will be putting a set of new stock bolts in to see if I notice any difference once the weather gets warm.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 11 Old 03-28-2013, 08:17 AM
the guy who did my HG's installed them and he does so on all the trucks he works on. (he did over 75 6.0 HG's last year)
05 F350 DRA
SCT Livewire TS with tunes from Innovative Diesel
PHP FICM Tuner
AFE Stage 2 Intake
Magnaflow 5" Exhaust
Studs
EGR Delete
2.5" leveling kit / 2" block
315/70R17 Hancook's
Custom Traction Bars 2" Double wall
Willy Mo is offline
post #10 of 11 Old 03-29-2013, 09:34 AM
As I recall, the theory behind the check valve in the banjo fittings was to prevent back flow or siphoning of the fuel out of the heads when the engine wasn't running. Is it true? I don't know, but judging by the responses here and elsewhere, it doesn't seem to hurt to put them in.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
