Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 01-26-2008, 04:44 PM
07stroker 07stroker is offline
I wanna go fast!!!
Still Puking...
well i blocked the EGR cooler in hopes of stopping the puking, but it still pukes when i get on it.. can anybody tell me why it is still puking??
Old 01-26-2008, 04:47 PM
mdiesel mdiesel is offline
not sure. but how do u like the VGT-SS turbo?
Matt
Old 01-26-2008, 04:48 PM
CLIPPERS CLIPPERS is offline
How does it run when you don't get on it?
Old 01-26-2008, 04:54 PM
I wanna go fast!!!
the turbo sounds awesome and spools up quick.. And during normal driving the truck runs normal, its just when i get on it that it pukes.
Old 01-26-2008, 05:02 PM
Deadblow Deadblow is offline
There could be a few thing wrong . First of all Do you have studs? if not it would be your head gaskets , If so them it mite be wraped heads. And do you know what your EGR vavle lookes like ? It mite be stuck open with would but boost in to the cooler and make it puk if theres a hole in the cooler
Old 01-26-2008, 05:11 PM
I wanna go fast!!!
It does not have studs and the EGR Valve is unplugged.
Old 01-26-2008, 05:20 PM
I think its time for studs and new head gakets , make sure who ever does it makes sure the heads are not warped when they go back on with them !
Old 01-26-2008, 06:10 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
I would start small and replace the cap first. is there any whistling? How high or low is the level of coolant in your bottle?
Old 01-26-2008, 06:15 PM
LvTitan LvTitan is offline
it could be a compromised head gasket. under load you may be getting some combustion pressure to leak thru and enter your coolant passages thus pressurizing your cooling system to the point of puking ...
or it could be the cap....
might be time for studs my friend.
Old 01-26-2008, 06:19 PM
RouDaddy RouDaddy is offline
How much do studs cost to get put in at the dealer, cab off?
