Broken Head Studs HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-26-2013, 09:47 PM Thread Starter
Alright guys I just got new head studs installed in my 2003 6.0 this weekend. Along with it I installed an egr delete kit. I found some studs on ebay that claim to be the strongest on the market and ratings very similar to arp's. I installed them and torqued them to what I have seen guys torquing their arp studs because these didnt come with suggested specs.
So I got one side installed and went in for lunch and when I came out to do the other side I found one stud that had broke off at the nut. Finally I got the project done (finding another stud). I have driven maybe 25 miles and found another broken off stud. Luckily these are the ones on the outside of the valve cover but WHY!!!!! Has anyone had this problem?
Also I had the batteries out the whole time. When I went to test drive it the transmission is shifting weird and slipping. Also the tow haul light comes on and flashes. What a weekend. Please help
sbveenker is offline
post #2 of 20 Old 03-26-2013, 09:54 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Why would you skimp on a job as critical as this? Sorry but your gonna have to rip it all back down and replace the gaskets yet again and this time reassemble it with ARP studs not some knock off brand claiming to be the same or better for less money. There is a reason we recommend specific parts. That is because they are tried and true and they work. Good luck man.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 20 Old 03-26-2013, 10:28 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yep, Bryan nailed it on the head. No place to be penny wise and pound foolish. It's a hard lesson.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #4 of 20 Old 03-27-2013, 02:22 AM
Originally Posted by sbveenker View Post
Alright guys I just got new head studs installed in my 2003 6.0 this weekend. Along with it I installed an egr delete kit. I found some studs on ebay that claim to be the strongest on the market and ratings very similar to arp's. I installed them and torqued them to what I have seen guys torquing their arp studs because these didnt come with suggested specs.So I got one side installed and went in for lunch and when I came out to do the other side I found one stud that had broke off at the nut. Finally I got the project done (finding another stud). I have driven maybe 25 miles and found another broken off stud. Luckily these are the ones on the outside of the valve cover but WHY!!!!! Has anyone had this problem?
Is this a joke? I hate to say it but you asked for this to happen. If your new headgasket isnt blown already you may look into changing out your studs one at a time with real head studs like ARP. Did you put OEM gaskets in when you did your studs? If not just take it all back apart like Tuscany said....
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #5 of 20 Old 03-27-2013, 08:34 AM
I agree with everyone else. you skimped on a vital part knowing ARP's reputation and not your's are breaking. I hate to say it, but time to spend more and re do everything.
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #6 of 20 Old 03-27-2013, 08:42 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1618 Post(s)
How much did the ebay studs cost you? It sure isn't going to offset doing the job again. Also I would rip it back apart asap. If they breaking outside the covers imagine what will happen when they break under the covers and the nut is loose while your driving...
Sent from AutoGuide.com App
toren302 is offline
post #7 of 20 Old 03-27-2013, 08:46 AM
dnf12908's Avatar
Quoted: 25 Post(s)
It's all been said. Couldn't agree more. Good luck.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #8 of 20 Old 03-27-2013, 08:50 AM
william_ace's Avatar
Quoted: 2 Post(s)
New Ford F250 F350 F450 F550 03 07 6 0L Powerstroke Diesel Head Stud Kit 20 Pcs | eBay
looks like it was probably these. eeek.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #9 of 20 Old 03-27-2013, 08:52 AM
portcity_gt's Avatar
Quoted: 1213 Post(s)
Live and learn. Now take it all apart and do it right.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #10 of 20 Old 03-27-2013, 09:00 AM
5fifty's Avatar
Wow, only $160 less than ARP's
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
