ICP Test - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-25-2013, 07:26 PM Thread Starter
ICP Test
Can i leave my truck in nuetrual and rev it to 4k to check my twin pump ICP?
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #2 of 6 Old 03-25-2013, 07:55 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
No, because ICP is load specific, just like boost.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 6 Old 03-25-2013, 08:27 PM Thread Starter
Damn that's what I thought but not what I wanted I hear
g2shuck is offline
post #4 of 6 Old 03-26-2013, 04:36 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Just put it on the road and stand on it for a while lol
How many gpm is your secondary pump at 4k rpm? I had a crude formula figured out to see how much flow is needed, based on injector size. Idk how accurate it is. I will see if I can dig it up.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #5 of 6 Old 03-26-2013, 05:34 AM Thread Starter
I know my pump is sized right I just need to check for leaks and I'm afraid of smoking the trans before Purdue lol
g2shuck is offline
post #6 of 6 Old 03-26-2013, 07:14 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Just start it up Gary and see how it runs and drives. If all is well, then just head to Purdue. I think as long as the pump isn't too big, then I can't see how it is possible to "default ICP". Unless I'm missing something, with the IPR valve fully open, the secondary pump would have to be flooding the HPO system to be able to cause a constant 4k+ psi in the rails. I think if this is happening, you're probably going to have other problems too.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
