running sct livewire on stock motor, couple ?s - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-25-2013, 11:00 AM Thread Starter
kcchief434's Avatar
im gonna be buying an sct 5015 tuner/monitor for my truck. im buying it from innovative and ill prob run the xtreme street tune and a tow tune. my truck runs perfect it is a 6.0 but i maintain it, oil changes fuel filters, etc. now i want this tuner because of the monitor and you can diagnose trouble codes so will this tuner tell me if im having any issues within the motor. ive done my research and i know i should get an egr delete and oil cooler and studs also the ficm reflashed but i live with the idea if it isnt broke dont fix it but i def do want to monitor the 6.0 just incase i do have to eventually dig deep into the pockets but will i be ok running custom tunes on the bone stock motor. i am def looking for more power plus my transmission doesnt shift right at all with my lift and 38's. also what can the livewire monitor i know watch engine oil/coolant temps. will it display ficm voltage or even a trouble code if im having egr issues?? thanks for any help
2006 ford f-350 crew cab 4x4 6.0 powerstroke
6 inch lift with 2 inch coil spacer
38/15.50r18 dick cepek mud country
kcchief434 is offline
post #2 of 8 Old 03-25-2013, 11:03 AM Thread Starter
kcchief434's Avatar
also i dont really abuse the truck always use additives as well andevery once in awhile i run it hard so it doesnt block up hopefully
post #3 of 8 Old 03-25-2013, 01:07 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You will find your answers here.
Anybody using the new live wire ts 5015 yet?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 8 Old 03-25-2013, 05:59 PM Thread Starter
kcchief434's Avatar
As big as that post was I couldnt really find the answer to my questions
post #5 of 8 Old 03-25-2013, 11:43 PM
You SHOULD be OK running custom tunes that are written for a STOCK motor.....there are some written for STOCK.....Some for MOD. motors.
Yes it will display FICM Volts.........It will display almost anything and everything....the only thing that I know of that it will NOT is fuel pressure......I'm running stock wheels/tires but I belive that you can change that on the Livewire.
2005 F350 Lariat FX4
Super Crew Long Box
SCT Livewire TS
mhines81 is offline
post #6 of 8 Old 03-26-2013, 04:33 AM
Powerstroke Techie
Lilpooh's Avatar
All your answers were in that thread!
Lilpooh is offline
post #7 of 8 Old 03-26-2013, 06:12 AM
portcity_gt's Avatar
Quoted: 1214 Post(s)
Also it will display fuel pressure with the addition of a $30 sending unit.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #8 of 8 Old 03-26-2013, 06:24 AM
Also op, the ts isn't going to "tell" you what's wrong, you have to know what you're looking for. That can be found in this thread.
Write Up: Monitoring the 6.0L PSD.
