Congrats Jugernaut!!! - Ford Powerstroke Diesel Forum
post #1 of 44 Old 03-25-2013, 05:48 AM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Good job Dale!! Congrats to becoming a "Tech" for the .org!!!
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #2 of 44 Old 03-25-2013, 06:03 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 958 Post(s)
Feedback Score: 6 reviews
Congrats!!! Now I can bug heck out of you asking asinine questions!!
Just kiddin, congrats again man!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 44 Old 03-25-2013, 06:13 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Thank you Rich and thank you to the .org Staff!!! I hope i live up to the honor!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #4 of 44 Old 03-25-2013, 06:14 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Anytime any place ill be there for yall !!!
A/C ASW A/W WINGS
post #5 of 44 Old 03-25-2013, 06:23 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Where were ya when I needed an injector harness schematic?
Just kiddin' Dale. Congrats!
dhanna6powerstroke is offline
post #6 of 44 Old 03-25-2013, 06:24 AM
RIP Cam!
Quoted: 958 Post(s)
Well I'll start ya off then ... I am in the process of replacing the HPOP and stand pipes on on the 03 6.0 at work. I have a lot of it torn down right now and will be taking the Y-pipes off today. I have read that the bolts to the exhaust manifold are 13mm on bottom and 10mm on top, is this correct? As far as removing the bolts do you have any quick tips, the room in that area is VERY limited. Also, as far as replacing the stand pipes, do you have any suggestions on removing the braided lines to get to them and what size socket do I need to replace them? Like I said, I am about to go do that today and any suggestions will really save me some time. Thanks in advance!!!
post #7 of 44 Old 03-25-2013, 06:33 AM
rr06psd's Avatar
Re: Congrats Jugernaut!!!
Congratulations!
2006 F-250 Lariat FX4 CCSB
BPD EGR Cooler
BPD Oil with cold Weather
Amsoil Bypass
Baldwin Coolant Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Silverline 4'' turbo back
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #8 of 44 Old 03-25-2013, 06:42 AM
Marine Raiders>Seals
najaf4life's Avatar
It's about time. congrats
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #9 of 44 Old 03-25-2013, 06:43 AM
portcity_gt's Avatar
Quoted: 1361 Post(s)
Yep 10 and 13mm, they're not bad to get to from the bottom. The hoses you push them down, move the coller in the direction of te arrows and pull apart. If you don't have a stc fitting tool, if you have one of those flat wrenches that comes with a grinder an will fit it will work. The stand pipe is a normal size I don't remember for sure but it was like 18-19 mm I think
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #10 of 44 Old 03-25-2013, 06:49 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Yes the exhaust to ypipes have a 10mm shoulder on them and the nut is 13mm,the sad part is they are sometime tough to get off!! You just have to get in there and get busy with it! I always replace the braided lines when i remove them if over 100k but some people dont its just a good idea to replace them if you have 100k or more on them and the socket is a 18mm or sometimes even a 19mm. The pease the braided line connect to is the check valve and i also replace them as well. The late 04 and up have the check valve in the stand pipe.
A/C ASW A/W WINGS
