Bully dog watch dog - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-24-2013, 05:39 PM Thread Starter
mikemike0409's Avatar
Bully dog watch dog
Is anyone using a one of these? I was looking at getting one of these.
mikemike0409 is offline
post #2 of 9 Old 03-24-2013, 06:54 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
I had a GT tuner for a while and loved the display set up. I am actually thinking about getting rid of the gauges and going to a watchdog.
toren302 is offline
post #3 of 9 Old 03-24-2013, 07:50 PM
MWilbur516's Avatar
Edge CTS FTW.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #4 of 9 Old 03-24-2013, 09:31 PM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
If you are looking for a monitor/programmer check out our Infinity. It has many more features than any of the other monitors on the market, including the ability to monitor Ford enhanced data, and run engine specific diagnostic tests. It can also hold an unlimited amount of custom tunes, media, datalogs, themes, etc. because it utilizes an external SD memory card that can be removed/replaced instead of having a limited internal memory. If you would like, check it out HERE.
Let me know if you have any questions about it.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 9 Old 03-25-2013, 05:31 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Justin, define custom tunes? yours only AKA Edge or is there an ETA on when they will alllow 3rd party tuners to write tunes to this device?
We're in for 2 if you can make that happen, if not then well we're out. There's more of us out here running true custom tunes than vanilla boxed versions.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #6 of 9 Old 03-25-2013, 06:56 AM
Bump To Pass!!
toren302's Avatar
Re: Bully dog watch dog
I have done a good amount of research on dp and think I might make the jump here. I like the abilities the infinity has. I would like to know the awnser to the custom tuning question asked above. I am sick of sct customer service. If this is a true custom tuner and all in one with better customer service I am in.
Sent from AutoGuide.com App
toren302 is offline
post #7 of 9 Old 03-25-2013, 10:41 AM
Quoted: 54 Post(s)
Denny
Custom tunes are tunes that are built for your truck and it's modifications. It is not a one size fits all tune that can be ran on every other truck. Another benefit that makes it "custom" is the ability for us to tweak the tune to your liking once you receive it, if you feel the need. We can adjust shift points, control ICP, etc... whereas with a canned tune from places such as Edge, Superchips, Bully Dog, etc., you are stuck with the tune you have. It cannot be adjusted or modified.
There is no ETA on when other tuners may be able to write tunes on this device because Drew Tech has only licensed us to put our tunes on it. This may or may not change in the future depending on what we are given the rights to do.
The Infinity is a true custom tuner. The tunes we write are classified as custom for the reasons I stated above. An adjustment of a tune is only an e-mail away.
Let me know if you have any questions at all about the Infinity. I would be happy to help you out.
DP-Tuner
Like us on
Justin Bochmann
post #8 of 9 Old 03-25-2013, 11:03 AM
Bump To Pass!!
toren302's Avatar
The only other question I have is what about egt and fuel pressure monitoring? Dose it have the ability to monitor fuel pressure with an add on sender? I know the watch dog can't so I was prepared to use it and the stand alone fuel pressure gauge.
toren302 is offline
post #9 of 9 Old 03-25-2013, 11:12 AM
Quoted: 54 Post(s)
Yes, the Infinity has room for two additional 0-5v sensor inputs. We already have the EGT probe and wiring available for it, and will be offering the fuel pressure sensor soon. We are also releasing a product that will enable the Infinity to have eight additional inputs instead of two. That product is in the final stages of testing and will be released shortly as well.
DP-Tuner
Like us on
Justin Bochmann
