the AD2 nightmare continues - Ford Powerstroke Diesel Forum
post #1 of 29 Old 03-24-2013, 08:15 AM Thread Starter
jwsland's Avatar
In less than a year, 4 motors, 2 upgraded wiring harness's, 2 regulators, 3 wrong filters and possibly a set of injectors due to fuel pressure related problems.
Moto2four has been a huge help through all of this.
Brand new motor, brand new 10gauge harness, left on the side of the road for who knows how many times now at work with no fuel pressure. Maybe the filter needs changing? Its been a couple months, not sure how many miles. I bought extra AD filters when I bought the unit. I was hoping to just buy a filter local now to avoid $10 shipping. Haha, not that easy. I drive and hour to my nearest international deal and have them cross reference Donaldson # P551315 to a Fleetgaurd filter, I buy two and drive home. They do not fit. They screw on but they hit the corner of the mounting bracket on the AD. So I made some adjustments to the bracket to allow it to clear, but nope, they do not screw on tight. It looks as if the metal flange inside the gasket is hitting a small black plastic piece on the AD. now in -$37 and some change. So I go to Napa, have the cross that same Donaldson number (that number is all over the forums as being the AD replacment filter) to a 2 micron Napa brand. Doesnt fit either, the gasket is slightly different and hits that black plastic piece on the AD. It goes on tight but wont make any pressure. I filled the filter and primed it, nothing. Now I'm another -$19.
What the hell is going on here? I didn't want to give AD another dollar but looks like I'm going to have to pay for thier filters and shipping. Maybe we can make this filter change more expensive!?
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 29 Old 03-24-2013, 08:45 AM
1fastTRX's Avatar
Re: the AD2 nightmare continues
Which filter did you fill with fuel? I had a priming issue the other day when I changed filters. I eventually filled the water separator to the very top and that took care of the priming issue. I'll list the ebay link where I got my filters from shortly.
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #3 of 29 Old 03-24-2013, 08:51 AM
1fastTRX's Avatar
These are the ones i just purchased and fit perfectly.
http://item.mobileweb.ebay.com/viewi...id=01617461790
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #4 of 29 Old 03-24-2013, 09:23 AM
steelnc's Avatar
Just had my AD 2 replaced under warranty last week. Lasted about 9 months. Spend $600+ on a fuel system you think it would last. Not happy to say the least.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
post #5 of 29 Old 03-24-2013, 09:34 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Just replaced a motor on my buddies Friday. $219 for the new motor. It's ridiculous how many issues people are having with air dog's.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 29 Old 03-24-2013, 09:37 AM
1fastTRX's Avatar
I didn't turn in the warranty card so 2 years later I had to pay $219 for a pump and new warranty card. I think I'll mail this card in. Certified mail, email, everything, because I definitely wasn't happy about paying so I need to make sure this one goes through. I plan on trying to find an electric motor shop that can replace the armature. Also want to possibly find replacement seals just to see if I can find replacement parts.
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #7 of 29 Old 03-24-2013, 09:40 AM
1fastTRX's Avatar
What was his total bill? They charged me $249 total. Im guessing the $30 is shipping, but that sounds a bit expensive.
4.10 gears
ARP Head Studs
Airdog II 165
6.4l Banjo Bolts
1fastTRX is offline
post #8 of 29 Old 03-24-2013, 10:45 AM
MWilbur516's Avatar
Are you guys using a sump with these or are you using the draw straw in the tanl to pull fuel? Also, who's running a reg. return. I know if you have a re. return with the air dog you should turn the AD all the way up and set the pressure at around 60-65psi at the regulator on the rear of the heads.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #9 of 29 Old 03-24-2013, 11:01 AM
steelnc's Avatar
No sump yet. As far as the reg. return it's not necessary on the ad 2. Mine is up to 65.
2014 F250 Platinum
Mini Max
5" Flo pro
steelnc is offline
post #10 of 29 Old 03-24-2013, 11:16 AM
MWilbur516's Avatar
The AD2 isnt what requires the return, it's the injectors that need the regulated return. With the dead head design of the heads on the 6.0l, a regulated return helps to feed all injectors equally. Now the ability to set the pressure lower, like at <60psi, is what helps the AD2. If the pressure is set too high, the AD will over work itself a die prematurely. You have to remember, the AD was designed as a lift pump, high volume low pressure, to then feed a high pressure pump (like an A1000 or equivalent), to then feed the injectors. I have heard of guys running a lower fuel pressure, like regulated return set to 50psi, with an AD and having no issues.
The biggest issue is that in a system were the AD is pulling from the tank (especially through the stock straw) and also pressurizing the fuel at the heads, its pulling double duty. This is not what the AD was designed for and is exceeding its limits, which leads to failure. The sump will definitely help as will the regulated return, but the system really needs a high pressure pump after the AD to be reliable.
