Dumb question on EGT sensor location - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-23-2013, 12:15 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
With my new turbo and injectors I've been watching the EGTs a lot. I even searched some old threads and read about EGT "before" or "after" turbo. Where would the before turbo location be? Where would the "after"? My EGT prob is tap'd right into the driv side exhaust manifold. Is that the right location to be referencing the standard numbers of 1250ish being max sustained ect? Thx, probably dumb questioned just never thought to ask
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #2 of 6 Old 03-23-2013, 12:20 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I guess what I'm askin is my sensor in the exhaust manifold considered "before" or "after" turbo? And do the temps go up or down after going thru turbo? Up I imagine,
Where Does the reading come from with guys using monitors? Or do you have to tap your own sensor? I don't know cause I have autometers and have mounted all the associated sensors
post #3 of 6 Old 03-23-2013, 12:23 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Yours is before and yes, that's where you want it.
dhanna6powerstroke is offline
post #4 of 6 Old 03-23-2013, 12:23 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Mine is tapped in the same spot as yours, drivers side exhaust manifold (pre-turbo).
The exhaust gases will be cooler post-turbo.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 6 Old 03-23-2013, 12:25 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Thanks much to you both!
post #6 of 6 Old 03-23-2013, 12:46 PM
Snake's Avatar
Quoted: 47 Post(s)
Agree with these.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
