2004 6.0 egr unplug yes or no? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-23-2013, 08:51 AM Thread Starter
chardnay10's Avatar
Question 2004 6.0 egr unplug yes or no?
I have an 04 6.0 with 4" exhaust and an edge evo tuner. I was wanting to know if it would be worth unplugging the egr valve or if if would cause problems i had it unplugged for a week and it ran way better with better throttle response and less turbo lag what would be a good choice on this? Someone told me it would mess stuff up if left unplugged.
chardnay10 is offline
post #2 of 22 Old 03-23-2013, 10:01 AM
BucOff's Avatar
Re: 2004 6.0 egr unplug yes or no?
I would just do the EGR delete with a custom tune. Relatively inexpensive and better for the truck...
Sent from AutoGuide.com App
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #3 of 22 Old 03-23-2013, 10:15 AM Thread Starter
chardnay10's Avatar
Yea thats what I will eventually do but for now would it be ok to just unplug? ive heard rumors of hydrolocking with it unplugged because of excessive pressure is that true?
post #4 of 22 Old 03-23-2013, 10:22 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
If you unplug it, it can cause cooling fan issues and turbo to not function properly. This is the case even with a custom tune with the EGR system turned off. Even if you do the delete, leave the actual valve in place and plugged in.
dhanna6powerstroke is offline
post #5 of 22 Old 03-23-2013, 10:28 AM Thread Starter
chardnay10's Avatar
Ok so i should just leave it alone until i do a delete then.
post #6 of 22 Old 03-23-2013, 10:45 AM
Mod Newbie
Quoted: 20 Post(s)
Even after you do the delete (which is mainly for removing cooler), I'd still leave the valve plugged in.
post #7 of 22 Old 03-23-2013, 10:51 AM Thread Starter
chardnay10's Avatar
Ok which delete do you recommend?
post #8 of 22 Old 03-23-2013, 10:56 AM
Mod Newbie
Quoted: 20 Post(s)
Everyone says the IPR Gen II delete is the best on the market. RCD makes a good kit and Sinister Diesel. I think most are comparable but I like the RCD kit. Only thing that suck is 2 of the bolts they send aren't really long enough but for$3-$4 you can get a couple bolts, washers and nuts. There will be lots of opinions on deletes but go with a one piece style to eliminate the possibility of a leak.
post #9 of 22 Old 03-23-2013, 06:48 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
The IPR Gen2 EGR Delete is without question the nicest on the market. I just put one on a members truck today. It is worth every penny. And yes, leave the egr valve plugged in.
RIP Mitch
the Org crew
PGreenSVT is offline
post #10 of 22 Old 03-25-2013, 02:45 PM Thread Starter
chardnay10's Avatar
So if i use this kit, will i need an sct tuner or will leaving the valve in place and plugged in not require one? IPR EGR Delete Kit for all 2003-2004 Ford Powerstroke 6.0 will fit F250, F350, F450
Tags
6.0 egr , egr delete , egr unplug
