BIG LEARNING EXPERIENCE FOR ME!! - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-22-2013, 07:40 AM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Well it starts off like this,one day trans started acting up after i rebuilt it with what i thought was stock tune. i called Suncoast and let me tell you these guys customer service is off the charts man they are awesome. Anyway i told them the truck is hanging in gear coming to a stop and when it shifts into 4 or 5th depending on temps it neutrals and bangs into gear. Wow i have to take trans out again i say with another call to suncoast know this is 3rd time out to find nothing. i replaced harness to trans and reinstall just to find it does same thing again.By this time im ready to drive truck into a tree!!! So i call suncaost again and the old guy says to me does this truck have stock tune and i said yes!! He said did i program it back to stock with my sct tuner i said yes!! LONG PAUSE!!!! He tells me this is the issue!!!??? Then he tells me to use my IDS to program truck back to stock and do a drive cycle!!! BINGO FIXED the sct somehow currupted my stock file and caused all of this!! so both of my tuners are at SCT AS WE SPEAK!! MAN IM PISSED!!! BUT I WOULDNT USE ANY OTHER PROGRAMMER So lesson learned pay attention when you put truck back to stock and make sure problems didnt start after you returned it to stock! If it can happen to me it can happen to anyone!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #2 of 17 Old 03-22-2013, 07:55 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Good info. Sorry for the bad luck.
dhanna6powerstroke is offline
post #3 of 17 Old 03-22-2013, 08:17 AM
Quoted: 5 Post(s)
Question: How did the trans act with tunes programmed on it? Would that have been a way to prove out the trans being good??
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 17 Old 03-22-2013, 08:22 AM
portcity_gt's Avatar
Quoted: 1193 Post(s)
Hmm, that's the same thing mine is doing.
Can the dealership reflash JUST the tcm and leave the ECM and ficm alone?
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 17 Old 03-22-2013, 08:24 AM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
I never ran it programmed because it wasnt acting right in stock form. When i originally had a issue with trans it was messed up and clutches where burned bad. So after i rebuilt trans first time it was probably ok but this was a different issue from the first issue! So that is what got me, i thought i did something wrong after first build when it was the stc going back to stock file from that point forward causing the issue!
A/C ASW A/W WINGS
post #6 of 17 Old 03-22-2013, 11:58 AM
jetjock15's Avatar
Quoted: 110 Post(s)
Dang, good info. What's the IDS though?
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 17 Old 03-22-2013, 12:02 PM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
The IDS is Ford's tool to program and perform diagnostics on the PCM.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 17 Old 03-22-2013, 12:13 PM Thread Starter
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
You would be better off flashing back with your device then starting from scratch! PCM tcm ficm
A/C ASW A/W WINGS
post #9 of 17 Old 03-22-2013, 12:25 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
This is GREAT info Dale. Thanks for sharing man.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 17 Old 03-22-2013, 12:44 PM
1fastTRX's Avatar
Re: BIG LEARNING EXPERIENCE FOR ME!!
Are the new parts you installed ruined as a result of the issues you were having? If so, did you have to purchase parts all over again? Or were you able to catch the issue before it started causing premature failure of the new stuff?
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
