Go go direct drive - Ford Powerstroke Diesel Forum
post #1 of 18 Old 03-21-2013, 04:50 PM Thread Starter
usnavyad's Avatar
Feedback Score: 3 reviews
Go go direct drive
Does anyone know where u can still get a direct drive from go go
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #2 of 18 Old 03-22-2013, 08:52 AM
PGreenSVT's Avatar
Good luck with that. Doug's head is so far up his azz these days that vendors are no longer carrying his stuff. He hasn't had his phone on for the last 2 weeks, doesn't respond to text messages and isn't delivering product he has committed to. Time to look into using an EPC solenoid.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 18 Old 03-22-2013, 10:48 AM
DoubleDpsd's Avatar
Re: Go go direct drive
See thread in general 6.0 discussion
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #4 of 18 Old 03-22-2013, 11:33 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
What's the EPC solenoid? You still haven't received your manifold? Maybe you should make a trip down here to Florida. lol
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #5 of 18 Old 03-22-2013, 11:54 AM
jetjock15's Avatar
Quoted: 110 Post(s)
What do these solenoids do? Maybe I need one - lol.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #6 of 18 Old 03-22-2013, 03:26 PM
PGreenSVT's Avatar
No I haven't and Doug has fallen off the end of the world so I am going forward with my own ported intake. I just sent it off to Adrian to weld back together for me and pressure test it. I wasted the better part of 3 months waiting on Doug. He is so far out of it he is useless at this point. So I should have my intake back in a couple of weeks or so and I can move on with my truck.
The EPC solenoid controls overall oil flow to all the other solenoids. The pressure can be set higher and it is basically the same thing as the Gogo direct solenoid but you can get it at any Ford parts house. You have to trim a couple tabs for it to fit right but that's trivial. It provide more pressure to the direct drive section firming up the shifts and eliminating shift flare. There a re a few threads here about this if you look.
post #7 of 18 Old 03-22-2013, 03:33 PM
jetjock15's Avatar
Quoted: 110 Post(s)
No time for research lol, do I need one?
post #8 of 18 Old 03-22-2013, 04:26 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I"m looking at getting an EPC as well, no GOGO for me.
I'll see if i can find the threads and re-post.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 18 Old 03-22-2013, 05:18 PM
PGreenSVT's Avatar
If your trans is shifting right and not flaring on you then NO, you don't NEED one. A little more juice on the direct clutches isn't a bad thing though.
post #10 of 18 Old 03-22-2013, 05:50 PM
Quoted: 2 Post(s)
I just found a source, 79.00 thanks to Gary!
PM me since they're not a vendor and I can't post their Info without ramifications.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
