billet wheel install- im polish and cant figure it out! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-20-2013, 06:33 PM Thread Starter
Hey guys- excited to get the new billet wheel in and im trying to install it on my powermax and cant break the compressor wheel off.... There is no nut on the turbine end. Its just a round circle that looks like a cap with a cut in it(i guess that cut is used for balancing it?).. Anyways does the compressor wheel on the p-max's have to be spun off with an impact gun?
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #2 of 6 Old 03-20-2013, 06:42 PM
whatever you don't use an impact gun.. it will cause stress cracks in the shaft. I had to take the exhaust housing off mine and hold the turbine and then use a wrench.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #3 of 6 Old 03-20-2013, 06:44 PM Thread Starter
ok... your the 2nd person that said that.. Why dont they have a nut on the turbine end like the stokers have?
bpd
Warren comp trans
04cr450 is offline
post #4 of 6 Old 03-20-2013, 07:07 PM Thread Starter
I got it.. Easy lol thanks guy
bpd
Warren comp trans
04cr450 is offline
post #5 of 6 Old 03-20-2013, 07:24 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Glad to hear you got it.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 6 Old 03-20-2013, 07:30 PM Thread Starter
hey nate. Yup I got it.. thought it would be a wham bam like the stock turbo.. Just split the turbo and held the turbine wheel with my hand and got the compressor wheel off that way.. Torqued to 10ft lbs.
bpd
Warren comp trans
04cr450 is offline
