What options? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-20-2013, 07:27 AM Thread Starter
surfingsnow510's Avatar
What options?
My lift just came in for my 04 f250 and I'll e getting some heavy a$$ military's for it, so I'll be lacking some power anyways, so I'm looking to bulletproof my truck. I've been thinking about this kit from alligator http://www.alligatorperformance.com/...ducts_id=11432
I'm just not sure on what additional options/ other parts I should order to make my truck bulletproof. I've been thinking this kit and maybe some new injectors and the h&s cold air intake from alligator too.
Thanks for your opinions,
Garrett Spradley
My lift and rims
04 f250 cclb; 8" Rough Country; 16x10 ion alloys; 38.5's xmls
surfingsnow510 is offline
post #2 of 3 Old 03-20-2013, 09:48 PM
jmeaby's Avatar
Quoted: 16 Post(s)
i wouldnt buy the solution kit for the truck the head gaskets are known to fail more then oem. what I would do is this...
1 arp headstuds with oem gaskets
while your down there do a egr delete and oil cooler rebuild.
2 coolant filter kit
3 aftermarket exhaust a lot of ppl do a 4inch turbo back
4 get monitor in there so you know what is up with the truck
(Fuel pressure,oil temp,coolant temp, egt are some good ones.)
then get some custom tunes in there and it will be a whole new animal just my 2 cents
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 3 Old 03-21-2013, 02:57 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Coolant filter kit and blue spring mod would be on the top of my list of billet proofing mods. Filter saves oil coolers and spring saves injectors.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
