my MTW stage 1 billet experience - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-19-2013, 06:28 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
This will be a runnin thread, I will keep you updated. I got my warren 155/30s and the MTW stage 1 with billet wheel installed tonight and got to do about 30 minutes of test driving and tried a couple different tunes.
The billet wheel stage 1 did not surge at all.
The first tune I tried was built for a powermax & 155s because my tuner has not worked with MTW yet and wanted to start there. With this tune the turbo spooled very slow and boost was very low. max boost in low 20s and high egts. I was spraying out black smoke all over the place - my truck has never done that - kind of fun to see.
then I loaded up my tunes I had previous, built for stock injectors and stock turbo. blew black smoke off idle, but not as bad. Turbo performed about as well as stock I would say, boost jumped pretty quick and maxed in the high 20s, I seen 28 psi once or twice. It seemed to get better towards the end of my test drive - and we know from experience - this is to be expected. I sent an email to Jodi (DP Tuner) with these inputs and asked him to send me a tune built for a stock turbo and 155s, and let me try that. From there we can tweak.
To early to give a good review, and I will not have the benefit of comparing stock to MTW turbo fairly because I upgraded to 155s at the same time and have no idea how the stock turbo would have done. I did see a lot of black smoke today, and that is a first for me.
Overall, im very happy that the turbo does not surge, and I have already seen 27psi on the fist test drive. Everything else is in the tuning, I will get it hooked it up.
Special thanks to Adrain for getting my turbo turned quick. I have a 800 mile trip this saturday and I told him I wanted it this week if at all possible, he made it happen. For a one man operation he does a great job.
I will update this post when I get the new tunes and test drive, hopefully tomorrow.
Side note:
My injectors kind of lope when i'm slowing down and the engine is idling, once at a complete stop it idles normal. Did it on all the tunes I tried, even ones that I have run with stock injectors that didnt do that - is that normal? Please answer in my other thread I posted about that to keep this one on track. Thanks much.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #2 of 22 Old 03-19-2013, 06:51 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Rob, I know you tow heavy. When do you expect to hook up the camper?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 22 Old 03-19-2013, 07:02 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Sir, I am doing a tour at the Pentagon right now so i am out of my normal routine and my trailer is in storage and my toys are in my garage. I am planning on pulling it out in the middle of may to do a short camping trip with family, for me to test the truck. However it will not be with the standard 4k lbs of off road toys I normally haul, or the 1400lbs of water or 600lbs of fuel, so the trailer will only be about 14k, but still will be a good test. I will post a review for sure.
post #4 of 22 Old 03-19-2013, 07:06 PM
Powerstroke Techie
Lilpooh's Avatar
Thank you, looking forward to your tow review.
Lilpooh is offline
post #5 of 22 Old 03-19-2013, 07:08 PM
madpowerstroke's Avatar
Rob, put the last performance tune you had for the stock turbo, and go from there. The MTW don't like the powermax tunes, they like the performance stock turbo tunes. As far as you lope, it is normal when you go to bigger injectors.
Here's what you should do but it's up to you. First put the performance stock turbo tune on, and have you tuner pull some fuel at the low end to get rid of the black smoke. Next get on here and tell me what your egt's are at wide open throttle, boost wide open and boost at cruise along with egt's. If you would like I can talk with the tuner to help them get it nailed quicker.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #6 of 22 Old 03-19-2013, 07:20 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Thanks Adrain! I'm I'm DC bro, I don't know where I'm going to get WOT! This city is to cramped. I also just got brand new nitto trail grapplers. These test drives not doing then any good - lol! I will let Jodi know and keep you posted.
post #7 of 22 Old 03-19-2013, 08:20 PM
twildman's Avatar
Quoted: 2 Post(s)
Try in the mall area, between the Lincoln Monument and the Smithsonian, lots of room in there.
Oh and by the way his name is spelled Jody, not Jodi.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #8 of 22 Old 03-19-2013, 09:23 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I'm sure you guys will get it nailed down Rob. This turbo is a nasty little thing let me tell you.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 22 Old 03-20-2013, 05:19 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
Here is tonights update: Jody sent me a tow and performance tune reworked for the MTW from yesterdays which were tunes based on Powermax. Much better....
This turbo never surges, and it does not even bark/fart on decel, ever - wow.
I loaded the Tow tune first, than the performance, and then went back to tow. It works great.
The tow tune boosted to 29psi a few times, most instances about 24-26. The egts at WOT max were about 1250-1300. No black smoke.
The Performance tune ripped. Boost well into the mid 30s, seen 34-35 range instanoues which backed down to 30-32. Egts did climb to about 1350 and I ran out of road and gear(4.56s I can only do about 90). No Smoke.
Bottom line is this turbo doesnt surge, and it can boost. It hits about the same boost numbers as my stock turbo did with Jody's tow and performance - and it doesn't surge. Even my stock turbo surged on Jody's tunes with the power really came on - the reason I wanted a new turbo to begin with. For anybody who uses this new MTW billet stage 1 and has low boost, its your tunes. As I have always said, Jody has more experience than anyone out there, no contest, he can always help you out.
Fams taking a 800 mile spring break round trip, leave sunday, will run the tow tune (not towing) the entire time. Hopefully my truck will learn the new mods and will really run great. I run a tow tune because I like the way it shifts and the mild onset of power. I have a performance tune for rare occasions when im at the dunes and have an itch!
Anyway, very happy, cannot wait to tow. I will pull my trailer out the second weekend of may just to tow it to a campground to take family out (really to test!). That will really be the true test because I built this setup to tow. The toyhauler will be empty and weight about 14k, but it will be a descent test. I will post a short update to this thread after my 800 mile trip this weekend and then post a new thread when I tow in May.
Thanks to this forum for suggesting this turbo. Thanks to MTW for hooking it up.
post #10 of 22 Old 03-20-2013, 05:31 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
That's awesome man. I'm really interested to hear how it does for you when you go towing across the desert again. Glad it's working out for you. The billet wheel makes the Stage 1 a honey of a turbo.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
