very strange running problem::: - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-18-2013, 11:29 PM Thread Starter
madpowerstroke's Avatar
This is very strange but I wanted to share. I reprogramed my FICM back to stock using PHP tuner. I removed relays and did all by the book, fired truck up and off I went. Truck ran really good, drove around for 2 hour trip, then later tried to do a run on it and blew a hose, so I limped back home. Next day I replaced the clamp and that was it, got ready to use the truck for running around truck. Got in trick started it and idled good, put truck in drive and gave it gas, and nothing. CTS was reading pedal position, but the truck would not rev, stuck it in park and truck reved fine stuck back in gear and nothing. I was scratching my head and the wife was on me, so I called Dale and asked him about it and if he ever saw it before. He told me to check for codes, and I felt like a a** I should have before calling him. Well I had a code that said FICM communication failure, so Dale said try to program the ECM stock so I did, and then truck ran fine. Put the performance tune back on and everything was good again. Very strange, can't explain it at all.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 7 Old 03-18-2013, 11:41 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Lol un solved mysteries
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 7 Old 03-18-2013, 11:51 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
It's a 6.0, they're strange, tempermental beasts
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #4 of 7 Old 03-19-2013, 03:58 PM
04cr450's Avatar
Adrian I had the same thing happen to me(not with the ficm tuning) but I was working on my truck and it sat for 3 weeks of so- batteries died, recharged them and ran the truck. Took off just like you had done, and bam truck just died, than would crank for 6-8 seconds and would not start. Recycled key again and truck started right up and has been runnin like a charm ever since(this happened 4- 5 months ago). I think I may have even pm'd Dale on the issue as well.. Unsolved mysteries lol
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 7 Old 03-19-2013, 04:44 PM
pizza pig's Avatar
The ficm communication code is always there after programming the ficm. At least for a few key cycles then goes away, it will go away automatically if you clear it. Normal. You have an issue somewhere I would think, but if it only happens once I wouldn't worry about it.
pizza pig is offline
post #6 of 7 Old 03-19-2013, 05:33 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
In the computer world we call the MES. Mysterious Electronic Sh1t.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 7 Old 03-19-2013, 08:06 PM
04cr450's Avatar
^ Kinda like in the hvac world- we call a "jumper" wire a IBD. International Bypass Device. Such professional talk.
bpd
Warren comp trans
04cr450 is offline
