Air filters?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-18-2013, 09:43 PM Thread Starter
black03's Avatar
Air filters??
So just got done with studs, egr delete, a MTW HYBRID just wondering if I should do away with the stock air intake setup or keep it? Advice??
2003 F350 PSD 6.0, Airlift Airbags front and rear. custom 4 inch-5inch exhaust. zoodad mod, ARP head studs, EGR delete, PMM Titanium head gaskets, MAD turbo werks hybrid, more to come
black03 is offline
post #2 of 4 Old 03-18-2013, 10:17 PM
sprksonu's Avatar
they say the stock air intake is good up to 500hp? if you are interested i have the Magnum FORCE Pro-GUARD 7 Stage-2 Si Intake System with outer wear and cleaning kit asking 250$ for it i payed close to 500$. it is one of the best intakes you can get here is the link Cold Air Intake System Stage-2 Si Magnum FORCE PRO*5R Stage-2 Si Intake System; Ford Diesel Trucks 03-07 V8-6.0L (td) 54-80392 - aFe Power
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 4 Old 03-19-2013, 12:38 AM
Justin@DP-Tuner's Avatar
Quoted: 47 Post(s)
The stock air intake system is fine for your setup. It flows really well and filters great.
However, an aftermarket system is fine as well. We carry Airaid and Banks systems if you are wanting to go that route. You can check them out HERE.
Let me know if you have any questions.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 4 Old 03-19-2013, 02:26 PM
personally i like the afe and s&b kits. i wont run anything else. i have the afe on mine now and have checked after @10k miles and there is no visable dirt getting past the filter.
mike
05 ccsb king ranch. 4" turbo back,egr delete, studs, ccv, 58v ficm tuned by eric, little extra fuel pressure, livewire tuned by vivian, mtw stage 1, 175/75s, afe cold air. hid's,led's recon led lights 5% tint80% windshield tint, high idle mod,fog/bright mod, train horns, 4" lift on 20x10s on 35's
amsoil dealer
05 smoker is offline
