Pillar pods - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-17-2013, 07:31 PM Thread Starter
419f250's Avatar
Pillar pods
I'm looking to get a quad pillar set up in my truck, besides a boost gauge (since I don't have one) what other three should I get? Just looking for a little help here, thanks.
419f250 is offline
post #2 of 8 Old 03-17-2013, 07:36 PM
JGman141's Avatar
Pyro, fuel pressure, hpop or trans temp
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 8 Old 03-17-2013, 07:41 PM
USAFBowman's Avatar
Pyro, oil temp, coolant temp
USAFBowman is offline
post #4 of 8 Old 03-17-2013, 07:47 PM Thread Starter
419f250's Avatar
Re: Pillar pods
No oil pressure?
419f250 is offline
post #5 of 8 Old 03-17-2013, 07:58 PM
JGman141's Avatar
Lpop hasn't been an issue with the 6.0. If anything watch the high pressure oil to make sure your not dropping icp
JGman141 is offline
post #6 of 8 Old 03-17-2013, 08:17 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Pillar pods
IMO, for the money spent on 4 gauges and a pod, you can get a digital monitor that will be able to watch WAY more, plus help with troubleshooting.
Write Up: Monitoring the 6.0L PSD.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 8 Old 03-17-2013, 08:24 PM
kcoyner's Avatar
Quoted: 57 Post(s)
I would go with HPOP, Fuel Pressure, Pyro, and reserve the bottom pod for an EDGE Insight CTS.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #8 of 8 Old 03-17-2013, 09:54 PM
scparrish's Avatar
Quoted: 79 Post(s)
Fuel psi, pyro, tranny but you will still need to see more
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
