Trouble changing tunes - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-17-2013, 10:21 AM Thread Starter
jwsland's Avatar
My sct powers up but won't get past the "turn key to on position" prompt. If it does, it quickly stops programming and the dash beeps and say "TBC Fault" then the sct doesn't finish. I know TBC is trailer brake controller but whats that have to do with the sct flashing the truck. My brake controler works perfectly fine, it has never once came on when towing and I tow daily.
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 2 Old 03-18-2013, 06:55 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Just for the sake of trying it, in the fuse box inside your engine bay, find the 2 amp fuse (white). File and clean the terminal ends. If that doesn't work, pull the TBC fuses and try loading.
Don't feel bad, Wildman's tune has hijacked my SCT. Anytime I want to put on a lighter tune after the Extreme, I have to go back to stock first, then reprogram or the truck won't start with the new tune.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
