Evil Eye's swap MTW Stage 1 Billet Compressor Wheel - Ford Powerstroke Diesel Forum
post #1 of 46 Old 03-17-2013, 07:58 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
I've pulled the 6.0L turbo a few times before so I won't bore you with those details. It went OK, well except that damn BACK BOLT!!! Oh and the fact that I began working on a hot engine, which isn't a good idea. For those that don't know it, the turbo stays hot for a LONG time, so putting bare skin on it probably isn't a good idea... unless you like getting branded.
BTW, I used Bryan's thread details in order to swap out the wheel. Thanks buddy! LINK
Turbo pulled and new wheel installed.
Another slightly tilted view. Think of it like a fashion show.
Cover back on and ready to go back in the truck
Y-pipe connection. If it isn't this tight when it goes back together, you will very likely have leaks. This is the MOST common area to experience a leak because it's hard to get to AND the turbo is heavy so it may require some negotiation to get it where you need it. I used a pry bar to gently encourage the turbo back into it's spot. Also be aware that you have to align it so that it drops onto the turbo drain without damaging the silicone o-ring.
Another view so you can see that it's already a tight connection. The clamp will NOT pull the two connections together so get it tight BEFORE putting the clamp on.
This is the downpipe side. You can adjust this side MUCH easier, so I left a little bit of gap on this side in order to get the y-pipe aligned.
There she is... Just BEGGING me to give it to her...
Downpipe clamp installed and tight
Y-pipe clamp installed and tight
Just for Bryan. I HATE the factory turbo hold down bolts and for good reason. They strip out and that's NEVER going to happen again thanks to these bad boys.
Test start and no leaks.
On the test drive, I realized that my downpipe shifted a bit and ended up touching the pinch weld on the cab. This caused quite a bit of noise inside the cab but is easy to fix. I use a 2x4 to to keep the downpipe away from the cab while I'm cranking down the lower clamp. If you don't it has a tendency to move around a bit. After torquing down the clamp, just pull out the 2x4 block.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #2 of 46 Old 03-17-2013, 08:17 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Sooooooooo? How's she run?????
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 46 Old 03-17-2013, 08:20 AM
william_ace's Avatar
Quoted: 2 Post(s)
I was wondering the same thing! We like the how-to, but need to know the details!!
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #4 of 46 Old 03-17-2013, 08:21 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Ran great up until the downpipe touched the pinch weld and added a horrible drone inside the cab. I will get that fixed this morning after my coffee.
Still too early to tell since I didn't have anything to cause it to surge, so won't know until later today.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 46 Old 03-17-2013, 08:22 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
yeah wheres the video lol normally satisfied with pics but never satisfied anymore. we need videos now!
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #6 of 46 Old 03-17-2013, 08:25 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 841 Post(s)
Feedback Score: 6 reviews
Get out there and really test that wheel ya slacker!!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 46 Old 03-17-2013, 08:27 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Video??? I need a cameraman (or woman)...
PS. LOTS of pics of the titanium bolts for Bryan... Especially that back one. At least now they will come out easy and no worry about stripping them out.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #8 of 46 Old 03-17-2013, 08:28 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Who needs turbo mounting bolts???
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 46 Old 03-17-2013, 08:50 AM
majek5's Avatar
Where did you get the Titanium bolts? Up-pipes are in my future.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #10 of 46 Old 03-17-2013, 09:26 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
***On Edit: I paid $33 and not $38 like I was thinking and updated my post***
I got them from BPD, who else? They got the idea after I rounded off the prior set of turbo bolts trying to pull my PowerMax to install the MTW Stage 1. I have to say that they are kind of pricey. I think I paid like $33 for the 3 bolts, BUT you can definitely tell the difference in quality. They threaded in SO much easier and only needed a wrench for the last half turn.
BTW, I just got the downpipe adjusted and left a little bit more blood on the turbo housing. That's what I get for being lazy and trying to balance on the front tire instead of pulling out my front step. Sliced my finger on the upper heat shield when I slipped off the front tire. Just a flesh wound, though...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
