not happy with extreme street to smokey and to much timing - Ford Powerstroke Diesel Forum
post #1 of 50 Old 03-15-2013, 05:45 AM Thread Starter
i was wondering if anyone has had the same concerns im haivng. my truck was totally stock with rcd egr delete and a diamond eye 4 inch turbo back exhaust. after talking to someone at innovative i was assured that the extreme street was safe for non studded trucks. so i bought it. i noticed that i was pushing 11-12 degrees of timing according to my livewire and it was extremely smokey and my transmission didnt shift very well either. I have since removed this tune and am now running matts srl and am much happier. but i was wanting to know if anyone else had this problem because i had heard lots of good things about erics tunes.
oh and my truck is a 2006 f350 srw single cab xl 4x4
kypowerstroke21 is offline
post #2 of 50 Old 03-15-2013, 06:11 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Did you contact Innovative to have the tune re-written to your liking??
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 50 Old 03-15-2013, 06:16 AM Thread Starter
No because they were going to charge me 50$ to rewrite the tune and when I ordered the tune I asked them to please keep smoke to a minimum and not a lot of timing.
post #4 of 50 Old 03-15-2013, 07:14 AM
That's surprising. They've always worked with me. I love Eric's tunes.
2016 F250 Lariat
the06wildebeast is offline
post #5 of 50 Old 03-15-2013, 08:03 AM
With my old injectors that had issues I have a good bit of smoke on X-st. Also I find the newer inferred strats run cleaner than the non-inferred strats. I'm not sure what be programmed you for but something to think about.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #6 of 50 Old 03-15-2013, 08:36 AM Thread Starter
I had heard nothing but good things from people that had them but I was just disappointed. How many degrees of timing do you see?
post #7 of 50 Old 03-15-2013, 08:38 AM Thread Starter
What do you mean by inferred strats? The truck was completely updated when I took it in for some work even though I told them not to update it
post #8 of 50 Old 03-15-2013, 09:08 AM
when you your truck is stock do you know what your strat is? also when you tuned it with either Erics or Matts have you checked what your strat is with that tune loaded.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 50 Old 03-15-2013, 09:41 AM
bkingsoda's Avatar
I ran Eric's Xstreet on my truck before the studs were put in and loved it. Not much smoke at all. Now with studs I'm running his Xrace tweaked a bit for a little more boost and still not a ton of smoke. Only puffs when you really load it up, just runs like a scalded ape. And I will say, Innovative has been awesome to work with. Great customer service and fast replies anytime I've emailed Eric. Sorry to hear you had a bad experience, I'm surprised to hear that.
2005 Lariat ccsb
ARP studs
Performance Machine egr delete
Performance Machine coolant filter
Sinister intake elbow
Metal cold side CAC
SCT SF3 tuned by Innovative
Blue spring and zoodad
Pioneer touch nav and full system
2.5" level with 35's
bkingsoda is offline
post #10 of 50 Old 03-15-2013, 10:11 AM
Quoted: 4 Post(s)
We've run the same style tuning on the tunes since 2003, when we released them. It's definitely safe for the truck and shifts should be dead on. I'd have to check out the tune, it could be a corruption issue, strategy issue, etc.
The Xtreme Street is usually clean and it's built for great power safely. Timing, injection pressure, etc. will change depending on conditions, boost, load, etc. Cylinder pressure is the enemy of stock gaskets and there's a variety of parameters that affect it.
We'll be glad to adjust your tuning to meet your needs. That's what we're here for, if there's an issue, we support it. We've been doing this for 12 years and don't plan on going anywhere. Send us an email or give us a call.
Thanks
InnovativeDiesel is offline
