Banks 6 gun with PDA - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-15-2013, 04:14 AM Thread Starter
Hello everyone I'm new to diesels I have owned my f250 for 2 years now bought it from the original owner who just used the truck to drive back an forth from work when I got the truck it had nothing done to it
I have put a 4 inch magnaflow exhaust turbo back on it an a s&b cold air intake on it a friend gave me his banks6 gun with a PDA monitoring system I haven't installed it yet because I'm not sure if it will do what I'm looking for
I mainly haul a horse trailer with it other than that its a daily driver for me
It does have high mileage an that's what has me a little nervous about connecting it but the miles are all high way miles not town mile if that makes any difference the hour meter on the truck reads a little over 5,900
Any thought , info will be greatly appreciated
Acbwv is offline
post #2 of 16 Old 03-15-2013, 05:02 AM
Oilylizard's Avatar
Use the monitor you got but get yourself an SCT.
2005 F-250 4X4
Harley Davidson Edition #00902
Leveled, Sinister Egr Delete, Studded, Sinister Coolant Filter, Rotella EC1 Coolant, 58v FICM, 6.4 Banjos, Blue Spring, SCT Tuned by Innovative, TSD
and the Wildman, Edge CTS W/ EGT Probe, 4" Turbo back straight pipe, CCV mod, 08 Tails, 08 Pan and filter, 08 Rear Diff Cover, 03 whistler
Oilylizard is offline
post #3 of 16 Old 03-15-2013, 05:18 AM Thread Starter
Does the sct control the transmission because I have been told the banks system doesn't do any transmission adjustments or does the banks adjust the transmission
Acbwv is offline
post #4 of 16 Old 03-15-2013, 05:24 AM
JGman141's Avatar
Yep sct will put a tune on the transmission as well. You really notice a difference with a custom tune.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #5 of 16 Old 03-15-2013, 05:39 AM
Oilylizard's Avatar
What he said
2005 F-250 4X4
post #6 of 16 Old 03-15-2013, 07:38 AM
Did you contact Banks and ask them?
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #7 of 16 Old 03-15-2013, 08:16 PM
JustinOOO9's Avatar
Quoted: 505 Post(s)
Garage
im sorry but I dont wanna bust anyones SCT bubble... but have you used the gauge to check your temps, and other items to see the health of your newer diesel?
your gonna wanna make sure your going to want to make sure your Engine coolant temp (ECT) and engine oil temp (EOT) are no more then 15 degrees apart. if they are your going to want to fix it right away. best test is to.
1. fully warm up truck
2 cruise above 60 like 65-70 ofr like 10-15 mins. mine is around 6 right now. if its above 15 need to have your oil cooler, possibly egr cooler situation corrected.
would be a bad idea to check your FICM voltage if your scanner can. make sure its above 46 volts.
change the fuel and oil filter with the ford OEM filters they are little more then the autozone crap but worth it in the end by 150%.
install a coolant filter from:
Dfuser
sinister
xdp, A few other but cant remember.
once your truck is all good then run a custom tune.
if you've already done this sorry to waste your time I just hear everyone tellin you to get a tuner first etc...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #8 of 16 Old 03-15-2013, 08:27 PM Thread Starter
I'm in the process of doing the egr delete started it today will be doing the head studs also
Has anyone used the banks 6 gun if so what did you think and if you replaced it with a different programer what did you switch to and why
Thanks
Acbwv is offline
post #9 of 16 Old 03-15-2013, 08:38 PM
mackattack6.0's Avatar
Re: Banks 6 gun with PDA
I have the six gun on mine (come with the truck) banks tech says all the tune does is monitor trans line pressure. No adjustments of any kind
'03 6.blow F250 CCSB lariat, ARP Studs, Ford Gaskets, New Oil Cooler 75k, XDP EGR Delete, SCT Livewire TS with Looney Wild from Vivian, MBRP 4" straight pipe, Blue Spring Update, Zoodad Mod, High Idle, Fog Light Mod, 73,XXX
mackattack6.0 is offline
post #10 of 16 Old 03-15-2013, 08:40 PM
Thanks
I have it on my 6.0 as soon as i have the money, im getting an sct livewire ts. Banks is ok but I've heard its a trans killer
