which intercooler and air intake to get ?? - Ford Powerstroke Diesel Forum
post #1 of 44 Old 03-14-2013, 12:01 AM Thread Starter
i want to get an aftermarket intercooler and air intake do you guys have any recommendations??
06-350 is offline
post #2 of 44 Old 03-14-2013, 01:31 AM
jmeaby's Avatar
Quoted: 16 Post(s)
S and b if u get a intake. Intercoolers banks makes a nice set up, most ppl say you need a pretty big turbo before you need a new intercooler. With a new intake you will flow better but lose how well it filters. I wouldn't let it stop me if I wanted a new intake just saying its not a must on the 6.0 a lot of ppl have dyno runs pushing 500 hp on the stock intake.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 44 Old 03-14-2013, 04:39 AM
I agree with what he said.
schnet1 is offline
post #4 of 44 Old 03-14-2013, 05:57 AM
portcity_gt's Avatar
Quoted: 1187 Post(s)
You could always wait for bulletproof deisel to release this one
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 44 Old 03-14-2013, 07:04 AM
rsama's Avatar
Don't forget about the spearco intercooler! As for intake, afe or s&b.
2004 F250 6.0
Sinister Egr Delete, 4" Mbrp turbo back straight pipe, Dieselsite coolant filter, Bluespring, Edge insight CS, Isspro gauges
rsama is offline
post #6 of 44 Old 03-14-2013, 07:52 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
for intake, I would say get S&B or AFE. I really don't think an intercooler is worth it without some pretty serious mods--turbo and injectors
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 44 Old 03-14-2013, 08:11 AM
Njstroker91's Avatar
^2 I would have to agree. I run an afe magnum force stage two dry filter and my intake temps are ambient and iat temp in the manifold is usually around 20 degrees above ambient. The oem cac is efficient. Most guys replace them cause of the plastic end caps are known not to hold up under high heat and boost levels
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #8 of 44 Old 03-14-2013, 08:18 AM
scparrish's Avatar
Quoted: 76 Post(s)
Spearco intercooler and s&b intake
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #9 of 44 Old 03-14-2013, 10:18 AM
unless your towing, WOT or a large turbo to counter huge amounts of fuel your not going to see anything from a intercooler just flowing with traffic down the road. Now I know my Banks did help with my PMax and stock injectors when WOT but just going down the road is within 25*F of stock. Sorta the samething with the stock air filter if your going down the road you can beat the stock box. Now when I had the stock box on the PMax it didn't take as long to get enough dirt to start pulling the filter minder. But the same thing with my after market I just clean it every oil change where the stock box I was putting a new filter in about every 10k ( I don't go over 25% clogged). With the stock turbo the stock filter took longer to get that amount of dirt so the filters lasted longer.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #10 of 44 Old 03-14-2013, 10:52 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Am I the only one that wants to know about the bullet proof one haha?
04 f250 cc sb.
jmeaby is offline
