Which light tow tune to go with? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-13-2013, 07:48 AM Thread Starter
06 Strokin's Avatar
Alright guys, next week Im headed down to jacksonville, tx for mud nationals. Its about a 300-350 mile trip and I'll be taking a suzuki king quad 750, vinson 500, and a yahmaha rhino on a 20 gooseneck. I've read where gearhead makes a 8k tow or a 10k for studded, which my truck is. Innovative diesel's street tune also lets you tow up to 10k. Are there any other ones Im missing or which one do yall think will fit best? Thanks.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 13 Old 03-13-2013, 09:23 AM
HHR124's Avatar
I have a Mini Max and tow a 13,000 5th wheel on mild which is the first boost setting above stock. It works great and EGT's stay below 1200.
2008 F-250 CC SWB King Ranch 4x4, 3.73, Job 3, stock looking so far...
B&W Gooseneck, Firestone Air Bags
Mini Max
Tows 2013 Voltage 3200 Toy Hauler
HHR124 is offline
post #3 of 13 Old 03-13-2013, 09:38 AM
JGman141's Avatar
My buddy tows with Vivian's tow tune and loves lts. But he regularly tows around 35-50k with his 550
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 13 Old 03-13-2013, 11:39 AM Thread Starter
06 Strokin's Avatar
I have a tow tune from Matt at innovative that I use to tow around 18-20k and it works pretty good. But since this is a pretty light load. I just wanted a bit more power and a little better mpg to go along with it.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #5 of 13 Old 03-13-2013, 12:14 PM
I have them all and my IDP 8K works the best in my truck. Pulling around 6k every weekend all summer. As soon as I hit lock up on the turn pike it does not come out. Pulls like a freight train
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
SCT tuned by Innovative
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
6.4 Banjo's Blue Fuel Spring
ELC Coolant/Sinister Filter
yarmish is offline
post #6 of 13 Old 03-13-2013, 12:58 PM
sprksonu's Avatar
matt's tow tune is 8k for non studded and 13k if you are studded
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #7 of 13 Old 03-13-2013, 04:00 PM Thread Starter
06 Strokin's Avatar
Oh ok, I got mixed up looking at them earlier.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #8 of 13 Old 03-14-2013, 09:18 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
BTS tunes on a SCT...his 100HP tow is fantastic!
CT Performance, Inc. is offline
post #9 of 13 Old 03-14-2013, 09:41 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1619 Post(s)
Re: Which light tow tune to go with?
Can you add some stats to that...? Kinda wondering how a 100hp tow tune works out. Egt, what weight you normally pull, just curious.
Sent from AutoGuide.com App
toren302 is offline
post #10 of 13 Old 03-14-2013, 10:16 AM
Quoted: 3 Post(s)
10k lbs through the Serrias..can't get over 1100*
