stock oem hpop or adrenaline.? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-12-2013, 07:08 PM Thread Starter
stevelaliberte's Avatar
Need to replace my hpop...now im wondering which one
Dieselsite Adrenaline *stock* pump ...or a real oem ford hpop ?
Steve Laliberte
Montreal
2003
Excursion 2wd
2012 front conversion
PowerMax turbo * BULLSEYE batmo wheel *
SCT livewire-innovative diesel tuned
Swamp 58v atlas 40
arp stud/ford oe hg
Sinister Coolant filter- atsdiesel Coolant-Recircluation
blue spring-6.4 banjo bolts
4"stainless exhaust
banks air intake/high ram elbow
Stealth ccvmod
Next: airdog, injector, water/meth
stevelaliberte is offline
post #2 of 8 Old 03-13-2013, 09:08 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Which ever has the longest warranty
CT Performance, Inc. is offline
post #3 of 8 Old 03-13-2013, 10:49 AM
I would go with oem... Dont hold me to this but i believe the adrenaline pump is NOT a new pump. You send your pump to them and they modify it with billet parts and basically upgrade the pump.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 8 Old 03-13-2013, 11:17 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
The adrenaline is as new as any pump you will get from ford. they use a billet housing and make a few other modifications, that are supposed to help it last longer. I am not sure it is worth the extra cost.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #5 of 8 Old 03-13-2013, 12:11 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
The 03 Adrenaline pump uses a billet housing and increases oil flow. The 05-07 that they are working uses the factory oem pump housing.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 8 Old 03-13-2013, 01:35 PM
scparrish's Avatar
Quoted: 92 Post(s)
Just put an adrenaline in and it looks awesome and has a better warranty than factory it is newer than a stock pump
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #7 of 8 Old 03-14-2013, 04:15 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I have the stock type adrenaline pump ,for about 1 year.So far so good.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #8 of 8 Old 03-14-2013, 04:27 AM Thread Starter
Ok thank you all for advice...i went with oem
Steve Laliberte
Montreal
2003
Excursion 2wd
Swamp 58v atlas 40
arp stud/ford oe hg
4"stainless exhaust
Stealth ccvmod
