Tuner Question for stock 6.0 - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-12-2013, 05:32 AM Thread Starter
iwbwemf's Avatar
I'm thinking about getting the IDP Custom 6.0L and 7.3L Pre-Programmed SCT Handheld Innovative Diesel 3015-ID Custom Pre-Programmed SCT Handheld. Can my truck handle this as is? I have an 07 6.0 F350 stock except for 4.56 gearing, Banks intake, and exhaust work. I don't want to mess anything up. This is my first Diesel. Thanks for the help.
'07 F350 SuperDuty 6.0
8" Fabtech Radius Arm Lift
37" Toyo Open Country
Banks Intake
Cat Delete
Muffler Delete
MBRP Exhaust dumped under the bed
Yukon 4.56 gears
SCT SF3 3015 tuner
IDP Xtreme Street tune
iwbwemf is offline
post #2 of 21 Old 03-12-2013, 05:40 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
just dont run the hottest tune. call innovative and ask them about the tune with the gears or if they need to write you a different one.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #3 of 21 Old 03-12-2013, 05:49 AM
Special's Avatar
Quoted: 2 Post(s)
I say yes, go for it. Your truck is close to the same as mine. IDP Extreme Street is the perfect tune for your truck. Just be aware that blown head gaskets are a known issue on stock or tuned trucks and extreme driving will increase your risk. I have been running IDP's Extreme Street for a few years now. I don't drive really hard, but I do try to stand on it at least once a week because I have heard that it is good for the engine. Only tow with the tow tune. Just start collecting the Bullet Proofing parts like Studs, Head Gaskets, Oil Cooler, and EGR Delete as they can go at anytime tuned or not. You will LOVE the Extreme Street Tune and be able to adjust for your gearing. Also if this is your first Diesel, be sure to run Opti-Lube XPD in your fuel and stay on top of your oil and filter changes as these are critical. You will learn a lot on this forum. Get tuned and you will be glad you did.
2005 Stampede Edition F-250 SuperDuty 6.SLO Diesel
4" Lift on 37" Toyo MTs ( IT CAN BE DONE ! )
Barder Stage 2 Turbo-Warren 175/30 Injectors-WPE Stage 3 Intake-DD RR-CTS2 Monitor-ARP Studs-BPD Remote Oil Cooler-Amsoil Custom 2 micron Full Flow Oil Filters-Sinister(Coolant Filter & CAC Pipes)-CCV Mod-Special's Fenderwell Mod-4:30 Gears-Grizzly Locker-Custom 5" Dual Straight Pipe Exhaust-AFE Momentum Intake-SCT Custom Tuned-Kleinn(630 Train Horns & Onboard Air)-HIDs-JL Audio-and Zoodad.
Special is offline
post #4 of 21 Old 03-12-2013, 05:51 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
There are lower cylinder pressure "non-studded tunes" and just run a cooler tune, it's good you have exhaust work done to keep those egts down! The mods you have will fair you well, may I recommend I coolant filter and and elc/ec-1 rated coolant and a monitor will be important with a tune, I'd get an sct live wire ts
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #5 of 21 Old 03-12-2013, 06:49 AM Thread Starter
iwbwemf's Avatar
Thanks for the help guys. I contacted IDP and here was their response:
"Yes but the top power tune the Anarchy Race is a little too much for a
stock truck...run the Performance Street or one of the lower powered
tunes as your daily driver....Performance Street...driven normal would
be the best for fuel mileage..
Hope this helps
IDP Sales"
Banks Intake
Cat Delete
Muffler Delete
Yukon 4.56 gears
SCT SF3 3015 tuner
iwbwemf is offline
post #6 of 21 Old 03-12-2013, 08:30 AM
Special's Avatar
Quoted: 2 Post(s)
I still suggest Extreme Street over Performance Street. Extreme Street is what the majority of the 6.0 guys on here voted to be the best tune for the stock 6.0. It feels plenty safe to me as a daily driver and the shifting parameters are well laid out. I have 6 different tunes and Extreme Street and Tow are the only two that I use anymore. I have been running it for around three years and I love it. I know that my gaskets may fail at anytime, but I have not installed my ARP Studs yet. I don't know how old you are or how you drive, but I think normal driving is plenty safe it is just when you are really standing on it that the cylinder pressures become too much. If you drive hard all of the time or want a little extra sercurity go with the Performance Street, but I don't think there is really that much difference between them. Extreme Street has been used for many years and has evolved into the perfect tune in my openion for the stock 6.0.
Special is offline
post #7 of 21 Old 03-12-2013, 09:36 AM Thread Starter
iwbwemf's Avatar
And Extreme Street is different than Anarchy Race too?
Does the Extreme Street help with turbo lag?
I'm 36. For the most part, I drive normally, but I like to act up and show the little ricers with their fart cans what a big diesel can do once in a while.
Banks Intake
Cat Delete
Muffler Delete
Yukon 4.56 gears
SCT SF3 3015 tuner
iwbwemf is offline
post #8 of 21 Old 03-12-2013, 09:49 AM Thread Starter
iwbwemf's Avatar
Just FYI, I also asked IDP about the Extreme Street tune, here is their response
"The Xtreme Street is the same as our Street performance on the 3015ID..
Same tune but just different name for that device.. Yes that is a really
great tune to run every day best one we recommend for daily driving even
on non studded trucks...."
Banks Intake
Cat Delete
Muffler Delete
Yukon 4.56 gears
SCT SF3 3015 tuner
iwbwemf is offline
post #9 of 21 Old 03-12-2013, 10:37 AM
Special's Avatar
Quoted: 2 Post(s)
Okay, good to know. Yes, the tune will completely change the way your truck runs. I am 34 so we probably drive alike. To be honest, when I first loaded the truck and made a lap around the block it seemed like way too much. I almost de-tuned it right away, but after a very short period of time I fell in love.
Special is offline
post #10 of 21 Old 03-12-2013, 10:41 AM
Special's Avatar
Quoted: 2 Post(s)
This tune has given my truck all of the power I need. Think about putting down over 700 ft/lb of torque! A gas motor would have to have about 800 hp. to do that. The tune will feel like night and day difference, like you have a different motor. Let me know when you follow through. I would love to hear your initial response. I know that you will be smiling from ear to ear!
Special is offline
