Is powermax better? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-10-2013, 08:53 PM Thread Starter
Silverbullet 6.0's Avatar
Is powermax better?
I got an 03 6.0 and I got a sct flash on it and I need a turbo and I don't want stock but don't wanna loose the whistle
Silverbullet 6.0 is offline
post #2 of 21 Old 03-10-2013, 09:10 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Nothing sounds like an 03 turbo, even a Powermax.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 21 Old 03-10-2013, 10:35 PM
jmeaby's Avatar
Quoted: 16 Post(s)
So he 03 is the best sounding?
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #4 of 21 Old 03-11-2013, 05:49 AM Thread Starter
Is powermax better?
Will it even come close to the same amount of whistle?
post #5 of 21 Old 03-11-2013, 06:02 AM
JGman141's Avatar
Mad stage one built with your 03 turbine wheel would be a nice set up. That way you still get the whistle and a bigger compressor wheel.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 21 Old 03-11-2013, 06:24 AM Thread Starter
Is powermax better?
Will I tell a difference in power with either of the turbos
post #7 of 21 Old 03-11-2013, 06:28 AM
JGman141's Avatar
Yes you will. Stock compressor wheel is 58mm x 82mm. Stage one and powermax are 63.5mm x 88mm. Power max uses dual plane wheel and mtw uses single plane wheel.
JGman141 is offline
post #8 of 21 Old 03-11-2013, 06:38 AM Thread Starter
Is powermax better?
But you can't tell a difference between stage one and powermax?
post #9 of 21 Old 03-11-2013, 06:50 AM
JGman141's Avatar
I have personally had no experience with either of these turbos. I would think that you would notice alittle more with the mtw because if the single plane. Single plane will out flow dual planes
JGman141 is offline
post #10 of 21 Old 03-11-2013, 07:18 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I believe that it will be doubtful that the OP will be able to tell a difference in power between a Pmax and a Stage 1 with an 03 turbine housing and wheel. Now perhaps if he had a billet wheeled Stage 1 there would be a difference, but the main reason he wont be able to tell much is because the stock injectors are already pretty much tapped out in the fuel delivery and in his case both turbos are going to be flowing more air than a stocker would so they both should give reasonable gains. I think the main reason for considering a Stage 1 over a Pmax would be cost and possibly slight performance advantage.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
