Gathering parts, do I need these?... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-10-2013, 07:26 PM Thread Starter
Dene2006's Avatar
I'm getting a shop to delete my ERG in an '04 Powerstroke. What are updated dummy plugs, and how many do I need please? Also, when he does this I am getting an OEM oil cooler also and what are updated stand pipes and how many of them would I also need?
Thanks
2004 F250 CCSB 2wd
SCT = Gearhead & Looney
MBRP 4" / S&B CAI
Borrowing money is like negotiating a pay cut for your future self...
Dene2006 is offline
post #2 of 8 Old 03-10-2013, 07:31 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
If they told you they were going to do a EGR delete and oil cooler and are going to do dummy plugs and standpipes they are going to charge you more labor to do those as they have to pull the valve covers to get to them. Just an FYI.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 8 Old 03-10-2013, 07:36 PM Thread Starter
Dene2006's Avatar
Thanks for the explination Tusc. I assumed that as long as he was doing the delete and cooler, these parts would be there for the easy change also. I didn't realize they were under the valve covers. Thanks, now I know what not to order.
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #4 of 8 Old 03-10-2013, 07:38 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I mean if your going for piece of mind than yes get them and have them installed. Just make sure your truck is in fact a late 04 with the wavy style HPO rails.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 8 Old 03-10-2013, 07:39 PM
portcity_gt's Avatar
Quoted: 1530 Post(s)
An 04 could be a grey area on dummy plugs it may have them may not.
If it has straight high pressure oil rails it dosnt take dummy plugs. If it has wavy rails it takes dummy plugs.
Both styles have stand pipes but they're different depending on the rails.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #6 of 8 Old 03-10-2013, 07:40 PM Thread Starter
Dene2006's Avatar
I know my truck is a late '04 and these couple of parts aren't expensive. Is it worth the extra labour to install them, (IE, is the piece of mind worth the price of the parts do you think?).
2004 F250 CCSB 2wd
MBRP 4" / S&B CAI
Dene2006 is offline
post #7 of 8 Old 03-10-2013, 07:44 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Either way you look at it the labor is going to be the same as they will have to pull the valve covers to change them. The valve covers do not have to be pulled for the oil cooler or egr cooler/delete and the intake manifold and oil cooler don't have to be pulled to do the standpipes and dummy plugs.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 8 Old 03-10-2013, 07:58 PM
nordstrom's Avatar
Quoted: 2 Post(s)
You know sometimes you a pretty fart smella Byan
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
