Best tune for 6.0 mtw stage 1 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-10-2013, 06:08 PM Thread Starter
RRFPD445's Avatar
What's the best tune for stock sticks and studs with a mad turbo werks stage 1 turbo. She's on canned tunes right now n doesn't like them. Thanks
Sent from AutoGuide.com App
2005 F250 Crew Cab Lariat
6.0L Powerstroke Diesel
Arp studs
Mad Stage 1 Turbo
Stock sticks
4" turbo back straight pipe
RRFPD445 is offline
post #2 of 4 Old 03-10-2013, 09:09 PM
nordstrom's Avatar
Quoted: 2 Post(s)
Eric at IDP or Vivian from quick tricks, Tony wildman. But their are others too every truck is different so you just got to start with one and go from their
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
post #3 of 4 Old 03-11-2013, 07:49 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
That is a loaded statement. Your truck should run just fine on the SCT pre-installed tunes. So, are you playing on words and momma wants more performance, or is your truck acting like a lame dog? If it is the latter, then you have to know what you might need to fix before installing a custom tune or know how the tune would fix your problem.
With stock studs, your biggest concern is your right foot and a hot tune. Cylinder pressure will be your biggest obstacle to longevity. I would steer clear of tunes that advance the timing (SOI) too much. You probably don't want a tune that spends most of its time at 8-12 BTDC, especially with large PWs (2.2-2.6). However, if you don't beat on it too often, even that would be OK. The other issue you may see occasionally is flash boil when you do put your foot into it. This is a wake-up call for you, because it looks similar to a head-gasket issue when it pukes. You must make sure you don't play too hard for too long (even if your EGTs look good) or you will super-heat the EGR cooler. If you stop soon after, it will flash boil the coolant.
So pick one, they all are about the same with a few small differences (some like, some don't) and levels of performance. Learn how to tweak it with the SCT variables and enjoy. But remember one thing, "If you break it, you bought it. No one did it to you!"
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 03-11-2013, 09:01 AM Thread Starter
RRFPD445's Avatar
Thanks guys. I found out that the boost sensor is bad which is why I'm having some problems. Getting it replaced today. But she's quick as chit after eating at a Mexican restaurant.
Arp studs
Mad Stage 1 Turbo
Stock sticks
RRFPD445 is offline
