Meth Injection does it add power? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-09-2013, 09:39 PM Thread Starter
I've been looking all around and googling specific to powerstroke 6.0 and meth injection. No one talks about the power gains they all praise lower EGT and better economy.
Such as this article with the cummins
Water-Methanol Injection: How Much is Too Much? - Diesel Power Magazine
Has anyone documented power increase amount with a tuned 6.0 and meth?
Thanks
makaveli200369 is offline
post #2 of 12 Old 03-10-2013, 07:13 AM
MWilbur516's Avatar
Bill at PHP has documented 50+rwhp gains on his kit running boost juice (49%meth by volume). I use -20* washer fluid (about 35-40% meth by volume) and have a VERY noticeable increase in power on the juice. I havn't dynoed it on the meth yet, but those numbers will be in soon enough. I have the AIS kit and couldn't be happier. My 6 gallon tank is installed in my tool box along with the pump. I arm the system off my AUX1 upfitter switch and my boost controller activates the system @ 15psi. I'm going to bump it to 20psi since the only time I need the added power is when I'm really in it anyhow.
ID:	80418   Click image for larger version
ID:	80426   Click image for larger version
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #3 of 12 Old 03-10-2013, 10:32 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I've been running water injection for around 7 years... I love it.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 12 Old 03-10-2013, 10:35 AM
MWilbur516's Avatar
I'll bow to Chris's opinion and expertise on this, but didn't you increase your water/meth output when you went to the MTW Hybrid over your 66 non-VGT?
post #5 of 12 Old 03-10-2013, 10:56 AM
strokin6L's Avatar
Quoted: 3 Post(s)
matt, I am running more water with the hybrid now than the 64mm non vgt because it makes the truck run hotter. Turbine housing on the hybrid just restricts it that much. I'll try and post those a couple vids later I have. Right now I have it coming on at 10psi and full at 20psi. With the 64mm non vgt I had it coming on at 15 and full at 30. You most definitly feel it when it comes on.
post #6 of 12 Old 03-10-2013, 10:57 AM
portcity_gt's Avatar
Quoted: 1188 Post(s)
Uh, YEA! Havnt you ever watched cops?......them kids can't be stopped when they're all hopped up on that chit. Meth is a hell of a drug.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #7 of 12 Old 03-10-2013, 11:14 AM Thread Starter
Thanks for the replies guys 50HP is a pretty good # plus the benefits of cooling the EGT. I'm thinking of getting the Snow performance MPG-MAX using the 49% also.
What is the temperature you are trying to stay away from melting pistons and components?
post #8 of 12 Old 03-10-2013, 11:29 AM
MWilbur516's Avatar
Look into the AIS kits. Excellent quality, ridiculous price and the pumps come with a lifetime warranty. I know a couple guys that had Snow pumps crap out on them and bought replacements pumps from AIS just because of th outstanding customer service and warranty.
post #9 of 12 Old 03-10-2013, 03:57 PM
i just purchased the snow performance stage 2 kit and i have the 7 gallon tank comming with it. im wanting to know about where you want to set the wather/meth to spray at what psi? any more info would b appericated. i really like the idea of what the kit actually does more power and less egt's
also are the pumps not reliable?
jherbie28 is offline
post #10 of 12 Old 03-10-2013, 06:23 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I was dead set on a snow kit, I'll have to look into bills and ais. Anyone on here running an ais kit? This is coming up on my list, as soon as my trans is straight I'll be looking to buy a w/m setup.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
