What could I expect? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-09-2013, 04:28 PM Thread Starter
Adamv7010's Avatar
Edited
Auto guide will not allow me to post the entire post...it cuts it short.
S366 66/73/.91.
Warren's 190/stock nozzles.
Cutting edge's divided t4 up pipes .
2006 f250 ccsb 4x4
rarely tow and when I do its less than 8k.
Normally elevation where I go is less than 750 ft.
Opinions on this setup?
Adamv7010 is offline
post #2 of 5 Old 03-10-2013, 10:39 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
It may provide the top end flow of air for 190s, but I think it will be laggier than you like.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 5 Old 03-10-2013, 11:30 AM
DoubleDpsd's Avatar
Re: What could I expect?
What about the 64/68/.83 divided instead
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #4 of 5 Old 03-10-2013, 12:25 PM
BACKYARDIGAN
Quoted: 4 Post(s)
The guy to talk to about running a non-VGT is Chris (Strokin6L). He has 190/75s and use to run them with a 64/71/.70 (I believe but the housing MAY have been a .76, hopefully he'll chime in). The key to whatever you run is getting divided up-pipes. From what I have heard and read, I wouldn't be running a T3 that's for sure. I'd be running a T4 divided. No diverter valves either.
Nate
post #5 of 5 Old 03-10-2013, 01:22 PM
pizza pig's Avatar
What power goals are you after? So many people go overkill on a street truck. I think you'd be better suited with a smaller charger.
pizza pig is offline
