I have a little project this summer - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-09-2013, 10:36 AM Thread Starter
As some of you know, one of my friends(kdogg85) blew a hole in his block. Now he has a dodge under the hood. Well, the guy that bought his engine and tranny didn't use all the parts that came with it. I bought the ported and polished heads, outlaw headers, ADII,and 205/100 injectors for $1200. So, with these goodies laying in the basement just shaking to be put to use and abuse again, I (with the wife's blessing) have decided to install them this summer. I am going to yank the motor and go through it, full re gasket, bearings, and re ring( had a smoking issue I can't track down for anything.) And I am going with new rods and pistons, as insurance.
Now down to the fun part, I am going to use the air dog as a pusher and feed a fuel lab hp pump. Does this sound like a reliable setup, plus I am making my own reg return. Oh, and a colt will be in the valley seeing as I am going to dismember the engine anyway. I will have an NADP trans in there as well.
As for a turbo, I am going to use a 366 since I don't tow anything anymore other than a bass boat.
Sound like something reasonable at least for the street.
07 ccsb 4x4, , swamps 58v(mild flash), rr, a1000, 225/50's, ported and polished heads, outlaw diesel headers, ported intake, dashboss fuel/egt, studs, twizted billet tranny
dfish1247 is offline
post #2 of 5 Old 03-09-2013, 02:59 PM
Gearhead2012's Avatar
Quoted: 2 Post(s)
Don't just re-ring the motor, especially if you're buying pistons anyway...how many miles are on the block you're going to be using? If you're serious order a good set of forged pistons from diamond or the like. If your block has more than 100k miles on it, you'll have more wear in the cylinder walls than I would recommend putting back together with stock pistons...it won't cost much to have the block bored and honed...I assume you were gonna have a machine shop clean it and magnaflux it for you anyway? It won't cost but a couple hundred more to have it bored and honed...pales in comparison to the cost of a set of carillos. You should also look at the harland sharp rocker arms...swapping heads and rockers and all can be dangerous, especially if you don't know what the valve height was set at...plus the OE rockers are total garbage...there's as much as .100" difference in lifter preload from one rocker to the next. Anyway good luck...if you have any questions during the build/rebuild pm me.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 5 Old 03-09-2013, 03:30 PM Thread Starter
I am going to have it checked out. It's getting honed at a minimum, and I was thinking h beams for rods anyway, plus main studs. Hadn't thought about rocker arms yet. I did check the heads and they are true flat. I know the drivers side had .002 and the pass had .004 removed when they were off before.
As for pistons, assuming the relative compression test I done is worth anything, the bores should be ok. They are getting mic'd regardless, but I was thinking coated stockers or coated forged. I have the money to pretty much do whatever, but don't want to send it more stupidly than I am.
post #4 of 5 Old 03-09-2013, 06:53 PM
Quoted: 2 Post(s)
Yeah I forgot to mention if the block is out, have it decked too...you don't really deck heads for straightness or flatness but more for surface finish. The block is often forgotten about...and probably to blame for white a few head gasket failures where the block prep or block surface finish wasn't adequate. Both the heads and block really need to be as smooth as possible.
I'm looking into solid roller options for the lifters to find a much more viable options price wise. That combined with adjustable rocker arms and good pushrods would do away with the major weak link as far as longevity goes. If you order custom pistons, spend the money wisely...order forged, the coatings help some, but you'll definitely want to lower the compression ratio a hair...how much boost you plan to run will determine by how much you'll drop the c/r. Keep us posted...could be a good build to keep an eye on this summer. Good luck.
Under construction
Machining the 6.0:
post #5 of 5 Old 03-10-2013, 06:15 AM
shawnb99's Avatar
why on earth did he install a gas motor in his truck, i was unaware DODGE made anything else....?
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
