oil cooler question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-08-2013, 06:27 PM Thread Starter
oil cooler question
Hey all, just want some sound advise on a game plan here. I just got my scangauge2 today and installit and took a drive to get some readings. First off my current ambient temp is roughly 35-40*F, anyway my coolant temp was in the 180-185 range while cruising, and EOT was 188-193*F. I thought I was good until I ran WOT uphill and my ECT jumped to 195, EOT 212! Although i got this high number whil coming up a significant grade, I still fear the inevitable, OIL COOLER TIME . Anywho, my question is, since Im on a somewhat tight budget, I will be replacing the stock oil cooler with a new Ford unit or the like. I would like to do a EGR delete or upgrade "while Im in there". So, could I get a few suggestions on what company has a solid EGR delete system? I was looking into the Sinister and XDP kits but I want a good setup, because I dont want to do this again!
Thanks everyone!
BobD981 is offline
post #2 of 11 Old 03-08-2013, 06:57 PM
I put on a sinister delete with the up pipe
Mason
03 F250 Lariat CCSB 4x4
4" Magnaflow turbo back, Bye Bye Kitty, Edge Insight CTS, EGR Delete, ARP Studs, SCT tuned by Tony Wildman
rebelmdb69 is offline
post #3 of 11 Old 03-08-2013, 07:04 PM
MWilbur516's Avatar
Look at Performance Machine kits. Great kits. IMHO Sinister stuff is wag overpriced. Here's a link.
6.0L Powerstroke COMPLETE EGR Cooler Delete Kit by Performance Machine & MFG.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #4 of 11 Old 03-08-2013, 07:44 PM
portcity_gt's Avatar
Quoted: 1393 Post(s)
I have a pmm kit on mine, with no problems.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #5 of 11 Old 03-09-2013, 03:39 PM Thread Starter
Thanks for the replies, Im glad I asked, or Id have spent an extra $80 on the same thing from sinister! greatly appreciate the help!
BobD981 is offline
post #6 of 11 Old 03-09-2013, 04:49 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I think you are getting ahead of yourself. First if your normal cruising ECT is 180-185 it would indicate that your thermostat is bad. Replace it and re-test. Second once you have a good thermostat in get the truck fully up to operational temp (190-192 ECT) and cruise it at 70-75mph for 10 minutes and see what your EOT and delta gets to.
Charging up a serious incline wide open throttle is no a good test.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 11 Old 03-09-2013, 04:56 PM
MacDougall's Avatar
I thought the delta test was suppose to be done on flat ground at 55mph not 70-75? but i could be completely wrong and mainly saying this so that i know better and so i know how to check from now on
Mike:
2003 F250 CCSB 4X4, 6.0L powerstroke.
-Sinister coolant filter
-Upgraded blue spring
-5" diamond eye exhaust W/ 6" tip
-Edge CS
-SCT tuner W/ vivians looney tune
MacDougall is offline
post #8 of 11 Old 03-09-2013, 05:54 PM
kcoyner's Avatar
Quoted: 74 Post(s)
Thanks everyone!
You're getting all cranked up a little to soon. Everything looks normal to me. Just keep an eye on things and drive your truck.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #9 of 11 Old 03-10-2013, 01:14 PM Thread Starter
Ok, thanks for the input guys, I do tend to expect the worst a little too soon! I had figured the low coolant temps were due to the inclimate weather here right now, but after doing the coolant flush procedure and intalling a dieselsite coolant filter today, checking my deltas, my temps were a consistent 5-10*F apart at 65mph with little load on the engine. Again coolant temps were low (178-185*f), so Ill get the t-stat ordered tomorrow.
Thanks again for pointing me in the right direction on this, I sometimes get carried away.
BobD981 is offline
post #10 of 11 Old 03-10-2013, 02:26 PM
PGreenSVT's Avatar
A better test is to run it at 70-75. This is not exactly the Ford procedure but it works well enough. Ford's procedure involves WOT runs.
RIP Mitch
the Org crew
